USB 3.0 SuperSpeed Device Cable (A to Micro-B
M/M), Blue, 6 ft. (1.83 m)
MODEL NUMBER: U326-006
Highlights
6-ft. (1.83 m) SuperSpeed USB
3.0 A to Micro-B Cable
10 times faster than USB 2.0,
with transfer rates up to 5 Gbps
System Requirements
Computers and Peripherals with
USB 3.0 capabilities
Package Includes
Connects a USB3.0 enabled computer to a USB3.0 peripheral with Micro-B type connector
Description
Tripp Lite's 6-ft. (1.83 m), USB-A to Micro-B SuperSpeed USB 3.0 cable brings significant performance
enhancements to the ubiquitous USB standard, while remaining compatible with the billions of USB
enabled devices currently deployed in the market. SuperSpeed USB will deliver 10x the data transfer rate
of Hi-Speed USB, up to 5Gbps, as well as improved power efficiency. USB 3.0 utilizes a bi-directional
data interface rather than USB 2.0's half-duplex arrangement, where data can only flow in one direction at
a time, giving a ten-fold increase in theoretical bandwidth.
Features
6-ft. (1.83 m) USB 3.0 SuperSpeed A-Male to Micro-B Male
SuperSpeed USB is 10 times faster than Hi-Speed USB, with transfer rates up to 5 Gbps.
SuperSpeed USB is a Sync-N-Go technology that minimizes user wait-time.
SuperSpeed USB will provide Optimized Power Efficiency...No device polling and lower active and idle
power requirements.
SuperSpeed USB is backwards compatible with USB 2.0. Devices interoperate with USB 2.0 platforms.
Hosts support USB 2.0 legacy devices.
Specifications
OVERVIEW
UPC Code
037332158147
USB Cable Type
Passive
PHYSICAL
Material of Construction
PVC
Cable Jacket Color
Blue
1/2
Male
Cable Jacket Rating
VW-1
Cable Outer Diameter (OD)
5.5MM
Cable Length (ft.)
6
Cable Length (m)
1.83
Cable Length (in.)
72
Shipping Dimensions (hwd / in.)
7.00 x 9.00 x 0.10
Shipping Dimensions (hwd / cm)
17.78 x 22.86 x 0.25
Shipping Weight (lbs.)
0.20
Shipping Weight (kg)
0.09
ENVIRONMENTAL
Operating Temperature Range
14 to 140 F (-10 to 60 C)
Storage Temperature Range
-4 to 185 F (-20 to 85 C)
Relative Humidity
10% to 85%, Non-Condensing
CONNECTIONS
Side A - Connector 1
USB 3.0 A (MALE)
Side B - Connector 1
USB 3.0 MICRO-B (MALE)
Connector Plating
Nickel
Contact Plating
Gold
FEATURES & SPECIFICATIONS
USB Specification
USB 3.0 (up to 5 Gbps)
STANDARDS & COMPLIANCE
Product Compliance
RoHS; CE (Europe); REACH; FCC (USA)
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
Lifetime limited warranty
© 2022 Tripp Lite. All rights reserved. All product and company names are trademarks or registered trademarks of their respective holders. Use of them does
not imply any affiliation with or endorsement by them. Tripp Lite has a policy of continuous improvement. Specifications are subject to change without notice.
Tripp Lite uses primary and third-party agencies to test its products for compliance with standards. See a list of Tripp Lite's testing agencies:
https://www.tripplite.com/products/product-certification-agencies
2/2
很抱歉,暂时无法提供与“U326-006”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+104.401131+13.57181
- 10+88.7452210+11.53659
- 25+83.1869425+10.81404
- 50+79.2146850+10.29766
- 100+75.43450100+9.80624
- 250+70.71488250+9.19271
- 500+67.34290500+8.75436
- 1000+64.132251000+8.33699
