USB 2.0 A to B Active Repeater Cable (M/M), 36
ft. (10.97 m)
Highlights
36-ft. USB A-B Active Cable
Overcomes the 5-meter USB
barrier
Built-in repeater maintains highspeed USB 2.0 signal quality
MODEL NUMBER: U042-036
System Requirements
A USB 2.0 port and USB 2.0
device (with type B jack) are
required to meet USB 2.0
speeds. A USB 1.1 port and/or
device can be used, but you will
not be able to achieve USB 2.0
speeds.
The U042-036 provides up to
150mA of power to the
connected device. If your device
requires more than 150mA of
power, it will either need to have
its own power supply; or, to be
plugged into a powered USB 2.0
hub (such as U222-007-R) that
is connected to the U042-036.
Locate a printer or other USB peripheral 36-ft. from your computer.
Package Includes
Features
Connect a computer to a printer or other USB device up to 36-ft. away
High-Speed USB 2.0 and USB 1.1 compatible
Active repeater maintains 480Mbps signal integrity
USB "A" to USB "B" connections
Windows 98/ME/2000/XP/Vista/WIN7/8/10 and MAC compatible
Cable length: 36-ft. Weight: 1 lb.
Repeater Pod dimension: 16.75 x 57.3 x 31.7 (mm.) / 0.7 x 2.3 x 1.3 (in.)
The U042-036 provides up to 150mA of power to the connected device. If your device requires more
than 150mA of power, it will either need to have its own power supply; or, to be plugged into a powered
USB 2.0 hub (such as U222-007-R) that is connected to the U042-036.
Specifications
OVERVIEW
UPC Code
037332138712
Technology
USB 2.0 (High Speed)
USB Cable Type
Active
PHYSICAL
Cable Jacket Color
Black
Cable Length (ft.)
36
Cable Length (m)
10.98
1/2
36-ft. Hi-Speed USB 2.0 Active
Cable
Shipping Dimensions (hwd / in.)
9.10 x 10.60 x 0.10
Shipping Dimensions (hwd / cm)
23.11 x 26.92 x 0.25
Shipping Weight (lbs.)
0.77
Shipping Weight (kg)
0.35
CONNECTIONS
Side A - Connector 1
USB A (MALE)
Side B - Connector 1
USB B (MALE)
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
3-year limited warranty
© 2022 Tripp Lite. All rights reserved. All product and company names are trademarks or registered trademarks of their respective holders. Use of them does
not imply any affiliation with or endorsement by them. Tripp Lite has a policy of continuous improvement. Specifications are subject to change without notice.
Tripp Lite uses primary and third-party agencies to test its products for compliance with standards. See a list of Tripp Lite's testing agencies:
https://www.tripplite.com/products/product-certification-agencies
2/2
很抱歉,暂时无法提供与“U042-036”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+399.375331+51.91750
- 10+339.4727610+44.13036
- 25+318.2244625+41.36815
- 50+303.0478450+39.39524
- 100+288.59799100+37.51681
- 250+285.52336250+37.11712
