USB-2000-CAH003
USB-2000-CAH003
    CICOIL
    USB 2.0 24AWG/2C-30AWG/1 SHLD 3'
USB-2000-CAH003 数据手册
4 D 3 2 ASSY. P/N: USB-2000-CAX003 USB-2000-CAX006 USB-2000-CAX012 "H"= HOST TO HOST OR "P"= HOST TO PERIPHERAL 2 ZONE REV ALL N/C NOTES, UNLESS OTHERWISE SPECIFIED: LENGTH IN FEET 1 1 INSTALL CONNECTORS AS REQUIRED 2 STRIP AND TIN PER IEC-J-STD-001 3 USE STRAIN RELIEF AS REQUIRED 4 INSTALL BLACK HEAT SHRINK AS REQUIRED OA 6 7 C 8 9 CROSS SECTION VIEW OF THE CABLE P/N: 579R101 WIDTH .31" HEIGHT .15" CONDUCTORS: ULTRA FLEXIBLE, FINELY STRANDED, TINNED COPPER "A" BILL OF MATERIALS, H-H; USB-2000 ITEM QTY PART NUMBER DESCRIPTION 1 A/R 579R101 CICOIL BULK SHIELDING: ULTRA FLEXIBLE, BRAIDED CABLE SHIELDS,WITH 90% NOMINAL COVERAGE 2 2 A-USBPA-3-R* ASSMANN USB TYPE A MINIMUM BEND RADIUS: 6X CABLE HEIGHT FOR CONNECTOR C INTERMEDIATE FLEX; 3 A/R PRODUCTION BLACK HEAT 10X CABLE HEIGHT FOR CONTINUOUS FLEX PREFERENCE SHRINK (-55°C TO FLEX LIFE: 10,000,000 CYCLES NOMINAL +135°C) OUTER JACKET DUROMETER RATING: 65 (SHORE A) "B" BILL OF MATERIALS, H-P; USB-2000ITEM QTY PART NUMBER DESCRIPTION 1 A/R 579R101 CICOIL BULK CABLE 2 1 A-USBPA-3-R* ASSMANN USB TYPE A CONNECTOR B 1 A-USBPB-2-R* ASSMANN 3 USB TYPE B CONNECTOR 4 1 PRODUCTION BLACK HEAT PREFERENCE SHRINK (-55°C TO +135°C) 10 TEMPERATURE RATING FOR CABLE: -65°C TO +165°C B 1 TEMPERATURE RATING FOR FINISHED ASSEMBLIES: -20°C TO +85°C 2 O B 11 OUTER JACKET DIELECTRIC STRENGTH: 450 VOLTS/MILS (17.7 kv/mm) 12 * OR EQUIVALENT THESE DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF CICOIL LLC AND ARE ISSUED IN STRICT CONFIDENCE AND SHALL NOT BE REPRODUCED OR COPIED OR USED AS THE BASIS FOR THE MANUFACTURE OR SALE 0F EQUPMENT WITHOUT PERMISSION. } VIEW PROJECTION STANDARD TOLERANCES UNLESS OTHERWISE NOTED DIMENSIONS ARE IN INCHES .X+/- 0.5 .XX+/-0.05 .XXX+/-0.005 ANGLES +/- 5 DEG [MM] A DATE SIGNATURE 24960 AVENUE TIBBITTS, VALENCIA, CA 91355 www.cicoil.com 661-295-1295 DRAWN: rruiz 12/4/2012 JOHN PALAHNUK 8/21/2013 TITLE CHECK USB CABLE ASSEMBLY ENGINEER JOHN PALAHNUK 8/21/2013 CAGE CODE DASH NO QTY REQD NEXT ASSEMBLY FINAL ASSEMBLY BY RR D 2 5 3 1 REVISION HISTORY DESCRIPTION DATE 12/04/12 INITIAL RELEASE MATERIAL: 19476 SIZE DRAWING NUMBER USB-2000-CAXXXX A REVISION N/C APPLICATION SCALE DO NOT SCALE DRAWING 4 3 2 SHEET 1 FILE: USB-2000-CAXXXX (C).idw 1 OF 1
USB-2000-CAH003 价格&库存
很抱歉,暂时无法提供与“USB-2000-CAH003”相匹配的价格&库存,您可以联系我们找货
