UR030-003
UR030-003
    TRIPPLITE
    UR030-003
UR030-003 数据手册
Universal Reversible USB 2.0 Converter Adapter Cable (Reversible A to 5Pin Mini B M/M), 3 ft. (0.91 m) Highlights ● Universal / Reversible A connector eliminates guesswork as to connector orientation ● Meets or Exceeds USB 2.0 Specifications ● Connects to Cameras, PDA's, etc with Mini-B 5-Pin connectors MODEL NUMBER: UR030-003 System Requirements ● Any USB device requiring a USB cable with Mini-B 5-Pin connector ● USB2.0 performance only when used with USB2.0 device and USB2.0 controller Package Includes ● Universal / Reversible "A" connector allows plugging in any direction Description Tripp Lite's UR030-003, 3-ft. (0.91 m), USB 2.0 Universal / Reversible "A" to Mini-B 5-pin device cable, meets or exceeds USB 2.0 Specifications. Connects a Digital camera, PDA, Cell Phone, etc to a USB port on a computer or hub. Backward compatible - can be used with older USB1.1 applications as well. All Tripp Lite USB 2.0 cabling include superior foil shielding for reliable, error-free data communications. The significantly faster data transfer rates of USB 2.0 (up to 480 Mbps) make them perfect for multimedia applications. Features nickel plated connectors and gold plated copper contacts for superior conductivity. The cable is manufactured with molded connectors and integral strain relief for extra durability and long life. Features ● Universal / Reversible "A" connector plugs in any direction ● Meets or Exceeds USB 2.0 Specifications ● Connects to Cameras, Cell Phones, PDA's, etc with 5-Pin Mini-B USB connectors ● Supports faster data transfer rate (1.5 to 480 Mbps) for low speed and high speed devices including multimedia applications ● Premium double-shielded cables with tinned copper braid and aluminum Mylar foil ● Nickel plated connectors and gold plated copper contacts for superior conductivity. ● Molded connectors and integral strain relief for extra durability and long life. Specifications OVERVIEW UPC Code 037332179524 Technology USB 2.0 (High Speed) 1/2 3-ft. (0.91 m) USB2.0 Universal / Reversible A to Mini-B Device Cable (A Male to 5Pin Mini-B Male) USB Cable Type Passive PHYSICAL Cable Jacket Color Black Cable Length (ft.) 3 Cable Length (m) 0.91 Shipping Dimensions (hwd / in.) 0.25 x 0.25 x 8.00 Shipping Dimensions (hwd / cm) 0.64 x 0.64 x 20.32 Shipping Weight (lbs.) 0.05 Shipping Weight (kg) 0.02 ENVIRONMENTAL Operating Temperature Range 14 to 122 F (-10 to 50 C) Storage Temperature Range 5 to 140 F (-15 to 60 C) Operating Humidity Range 0% to 90% RH, Non-Condensing Storage Humidity Range 0% to 90% RH, Non-Condensing CONNECTIONS Side A - Connector 1 REVERSIBLE USB A (MALE) Side B - Connector 1 USB MINI-B 5-PIN (MALE) WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2022 Tripp Lite. All rights reserved. All product and company names are trademarks or registered trademarks of their respective holders. Use of them does not imply any affiliation with or endorsement by them. Tripp Lite has a policy of continuous improvement. Specifications are subject to change without notice. Tripp Lite uses primary and third-party agencies to test its products for compliance with standards. See a list of Tripp Lite's testing agencies: https://www.tripplite.com/products/product-certification-agencies 2/2
UR030-003 价格&库存
很抱歉,暂时无法提供与“UR030-003”相匹配的价格&库存,您可以联系我们找货
