USB-3000-CAH006
USB-3000-CAH006
    CICOIL
    USB 3.0 Cable A Male to A Male 6.00' (1.83m) Shielded
USB-3000-CAH006 数据手册
4 D 3 2 ASSY. P/N: USB-3000-CAX003 USB-3000-CAX006 USB-3000-CAX012 2 "H"= HOST TO HOST OR "P"= HOST TO PERIPHERAL ZONE REV ALL N/C NOTES, UNLESS OTHERWISE SPECIFIED: 1 2 O 1 INSTALL CONNECTORS AS REQUIRED 2 STRIP AND TIN PER IEC-J-STD-001 3 USE STRAIN RELIEF AS REQUIRED 4 INSTALL BLACK HEAT SHRINK AS REQUIRED B 1 2 OB D "A" BILL OF MATERIALS, H-H ITEM QTY PART NUMBER DESCRIPTION 1 A/R 580R101 CICOIL BULK CABLE 2 2 A-USBPA-3-R* ASSMANN USB TYPE A CONNECTOR 3 1 PRODUCTION BLACK HEAT C PREFERENCE SHRINK (-55°C TO +135°C) 5 CONDUCTORS: ULTRA FLEXIBLE, FINELY STRANDED, TINNED COPPER 6 SHIELDING: ULTRA FLEXIBLE, BRAIDED SHIELDS,WITH 90% NOMINAL COVERAGE 7 MINIMUM BEND RADIUS: 6X CABLE HEIGHT FOR INTERMEDIATE FLEX; 10X CABLE HEIGHT FOR CONTINUOUS FLEX 8 FLEX LIFE: 10,000,000 CYCLES NOMINAL 9 OUTER JACKET DUROMETER RATING: 65 (SHORE A) C BY RR CROSS SECTION VIEW OF THE CABLE P/N: 580R101 WIDTH .62" HEIGHT .18" LENGTH IN FEET A 3 1 REVISION HISTORY DESCRIPTION DATE 12/04/12 INITIAL RELEASE 10 TEMPERATURE RATING FOR CABLE: -65°C TO +165°C TEMPERATURE RATING FOR FINISHED ASSEMBLY: -20°C TO +85°C 11 OUTER JACKET DIELECTRIC STRENGTH: 450 VOLTS/MILS (17.7 kv/mm) "B" BILL OF MATERIALS, H-P ITEM QTY PART NUMBER DESCRIPTION 1 A/R 580R101 CICOIL BULK CABLE 2 1 A-USBPA-3-R* ASSMANN USB TYPE A CONNECTOR 1 A-USBPB-3-R* ASSMANN 3 USB TYPE B CONNECTOR B 4 1 PRODUCTION BLACK HEAT PREFERENCE SHRINK (-55°C TO +135°C) 12 * OR EQUIVALENT THESE DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF CICOIL LLC AND ARE ISSUED IN STRICT CONFIDENCE AND SHALL NOT BE REPRODUCED OR COPIED OR USED AS THE BASIS FOR THE MANUFACTURE OR SALE 0F EQUPMENT WITHOUT PERMISSION. STANDARD TOLERANCES UNLESS OTHERWISE NOTED DIMENSIONS ARE IN INCHES .X+/- 0.5 .XX+/-0.05 .XXX+/-0.005 ANGLES +/- 5 DEG [MM] A } VIEW PROJECTION DATE SIGNATURE 24960 AVENUE TIBBITTS, VALENCIA, CA 91355 www.cicoil.com 661-295-1295 DRAWN: rruiz 12/4/2012 JOHN PALAHNUK 8/21/2013 TITLE CHECK USB CABLE ASSEMBLY ENGINEER JOHN PALAHNUK 8/21/2013 CAGE CODE DASH NO QTY REQD NEXT ASSEMBLY FINAL ASSEMBLY MATERIAL: 19476 SIZE A DRAWING NUMBER REVISION USB-3000-CAXXXX N/C APPLICATION SCALE DO NOT SCALE DRAWING 4 3 2 FILE: USB-3000-CAXXXX (C).idw 1 SHEET 1 OF 1
USB-3000-CAH006 价格&库存
很抱歉,暂时无法提供与“USB-3000-CAH006”相匹配的价格&库存,您可以联系我们找货
