FIT0479
FIT0479
    DFROBOT
    DOUBLESIDEDMICROUSBCABLE
FIT0479 数据手册
  Double Sided Micro USB Cable SKU:FIT0479 INTRODUCTION This USB 2.0 cable has a USB to microUSB connection. The USB connector is double sided so it can be connected in either orientation and includes an etched LattePanda logo. Each connector has super antioxidant properties for stable performance and durability. The cable can handle current up to 2.1A for fast charging and data transmission. The cable's insulation uses a flat noodle cable design which eliminates any chance of tangling. This is the perfect choice for your LattePanda, smartphone, tablet or any other device that requires fast charging.     What is a LattePanda? A LattePanda is a complete Windows 10 single board computer! It includes everything a regular PC has and can do anything that a regular PC does. It is compatible with almost every gadget you know: printers, joysticks, cameras and more. Any peripherals that work on your PC will work on a LattePanda. A LattePanda comes pre-installed with a full, preactivated version of Windows 10, where you can install powerful tools such as Visual Studio, NodeJS, Java, Processing, and more. Using existing APIs, you can develop your own software and hardware projects on a LattePanda as you would on a normal PC - C#, Javascript, Ruby and so on. Say goodbye to your bulky laptop! SPECIFICATION  Double-sided USB 2.0  USB to microUSB interface  Up to 2.1A output, supports high speed data transmission and can charge your mobile phone at the same time  Flat noodle cable design - no tangling!  High stability, multi-stage voltage protection, superior safety performance  Cable Length: 1m/3.28'  Material: Aluminum shell, TPE SHIPPING LIST  Double Sided Micro USB Cable x 1 https://www.dfrobot.com/product-1430.html?search=FIT0479&description=true/10-28-19
FIT0479 价格&库存
很抱歉,暂时无法提供与“FIT0479”相匹配的价格&库存,您可以联系我们找货
FIT0479
    库存:13
