U040-006-MINI
U040-006-MINI
    TRIPPLITE
    U040-006-MINI
U040-006-MINI 数据手册
USB 5-Pin Mini-B to USB-C Cable - USB 2.0, (M/M), 6 ft. (1.83 m) MODEL NUMBER: U040-006-MINI Highlights ● 6-ft. USB 2.0 5-Pin Mini-B Male to USB Type-C (USB-C) Male cable ● USB Type-C connector is reversible, so there is no guessing on which way to plug it in ● Supports USB 2.0 data transfer rates up to 480Mbps System Requirements ● A device with a 5-Pin Mini-B connector ● A tablet, laptop, ultrabook or computer with a USB Type-C (USB-C) port. Package Includes ● Connect devices with a 5-Pin Mini-B connector to the USB Type-C (USB-C) port on your tablet, laptop, ultrabook or computer Features ● 6-ft. USB 2.0 5-Pin Mini-B Male to USB Type-C (USB-C) Male cable ● USB Type-C connector is reversible, so there is no guessing on which way to plug it in.....it connects in either direction! ● Supports USB 2.0 data transfer rates up to 480Mbps ● Backward compatible with previous USB generations ● Gold plated contacts and molded ends provide a lifetime of use ● 28AWG Data Pair / 20AWG Power pair; Supports 500mA current Specifications OVERVIEW UPC Code 037332188601 Technology USB 2.0 (High Speed) USB Cable Type Passive PHYSICAL Material of Construction PVC Cable Jacket Color Black Cable Jacket Rating VW-1 Cable Outer Diameter (OD) 3.5MM 1/2 USB 2.0 5-Pin Mini-B Male to USB Type-C (USB-C) Male Cable - 6-ft. Cable Length (ft.) 6 Cable Length (m) 1.83 Cable Length (in.) 72 Shipping Dimensions (hwd / in.) 9.00 x 7.00 x 0.50 Shipping Dimensions (hwd / cm) 22.86 x 17.78 x 1.27 Shipping Weight (lbs.) 0.09 Shipping Weight (kg) 0.04 ENVIRONMENTAL Operating Temperature Range 14 to 140 F (-10 to 60 C) Storage Temperature Range -4 to 185 F (-20 to 85 C) Relative Humidity 10% to 85%, Non-Condensing CONNECTIONS Side A - Connector 1 USB C (MALE) Side B - Connector 1 USB MINI-B 5-PIN (MALE) Connector Plating Nickel Contact Plating Gold FEATURES & SPECIFICATIONS USB Specification USB 2.0 (up to 480 Mbps) WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2022 Tripp Lite. All rights reserved. All product and company names are trademarks or registered trademarks of their respective holders. Use of them does not imply any affiliation with or endorsement by them. Tripp Lite has a policy of continuous improvement. Specifications are subject to change without notice. Tripp Lite uses primary and third-party agencies to test its products for compliance with standards. See a list of Tripp Lite's testing agencies: https://www.tripplite.com/products/product-certification-agencies 2/2
U040-006-MINI 价格&库存
很抱歉,暂时无法提供与“U040-006-MINI”相匹配的价格&库存,您可以联系我们找货
