USB 2.0 A to B Active Repeater Cable (M/M), 50
ft. (15.24 m)
MODEL NUMBER: U042-050
Highlights
Bus-powered signal booster
extends USB signal range
Supports data transfer rates up
to 480 Mbps
Provides 150mA of power to
connected device
Plug and play with no power
supply, drivers or software
needed
Compatible with all major
operating systems
System Requirements
USB port and USB-B device
(USB 2.0 port and device are
necessary to achieve USB 2.0
speeds)
If connected device requires
more than 150mA of power, it
will either need its own power
supply or to be plugged into a
powered USB 2.0 hub (such as
Tripp Lite's U222-007-R)
Mac, Windows, Linux, Sun or
any other operating system with
a USB port
Connects your computer to a printer, scanner, card reader or other USB-B peripheral up to 50 ft. away
with no loss in signal quality or performance.
Description
The Tripp Lite U042-050 USB 2.0 Hi-Speed A/B Active Repeater Cable (M/M) extends the distance
between a USB Type-A device and a USB Type-B device up to 50-ft. (15.24 m). Because the USB 2.0
specification limits the distance between devices to just over 16-ft. (4.88 m), the U042-050 features a buspowered signal booster that extends the USB signal's range with no loss in signal quality or performance.
Ideal for connecting a printer, scanner or card reader to a host computer up to 50-ft. (15.24 m) away, the
U042-050 supports data transfer rates of 480 Mbps and provides up to 150mA of power to the connected
device (if your device needs more than 150mA of power, it will either need its own power supply or to be
connected to a powered USB 2.0 hub, such as Tripp Lite's U222-007-R). It meets or exceeds USB 2.0
specifications and is backward compatible with previous USB generations.
The U042-050 is plug-and-play with no external power supply, drivers or software required. You can hotswap connected devices - for instance, unhook your printer and connect a scanner - without having to
power down the computer. This active repeater cable works with all major operating systems.
Premium aluminum Mylar foil and tinned copper braid shielding protects your connected devices from
EMI/RFI interference. Molded nickel-plated connectors with gold-plated copper contacts ensure excellent
conductivity. Integral strain relief ensures the cable and connectors last a long time.
Features
Extends USB Signals Up to 50-ft. (15.24 m)
● Bus-powered signal booster extends range with no loss in signal quality or performance
Ideal for connecting printer, scanner or card reader to computer up to 50-ft. (15.24 m) away
High-Speed Data Transfer for Multimedia Applications
● Supports data transfer rates of 480 Mbps
Provides up to 150mA of power to connected device
Meets or exceeds USB 2.0 specifications
Backward compatible with previous USB generations
Broad Compatibility
1/2
Package Includes
(M/M), 50-ft. (15.24 m)
Plug and play with no power supply, drivers or software needed
Compatible with all major operating systems
Hot-swap devices without powering down computer
Superior Construction for Superior Performance
● Premium foil and braid shielding protects devices from EMI/RFI interference
Molded nickel-plated connectors with gold-plated copper contacts ensure excellent conductivity
Integral strain relief ensures cable and connectors last a long time
Specifications
OVERVIEW
UPC Code
037332192752
Technology
USB 2.0 (High Speed)
USB Cable Type
Active
PHYSICAL
Cable Jacket Color
Black
Cable Length (ft.)
50
Cable Length (m)
15.24
Shipping Dimensions (hwd / in.)
10.60 x 9.10 x 0.50
Shipping Dimensions (hwd / cm)
26.92 x 23.11 x 1.27
Shipping Weight (lbs.)
1.08
Shipping Weight (kg)
0.49
CONNECTIONS
Side A - Connector 1
USB A (MALE)
Side B - Connector 1
USB B (MALE)
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
3-year limited warranty
© 2022 Tripp Lite. All rights reserved. All product and company names are trademarks or registered trademarks of their respective holders. Use of them does
not imply any affiliation with or endorsement by them. Tripp Lite has a policy of continuous improvement. Specifications are subject to change without notice.
Tripp Lite uses primary and third-party agencies to test its products for compliance with standards. See a list of Tripp Lite's testing agencies:
https://www.tripplite.com/products/product-certification-agencies
2/2
很抱歉,暂时无法提供与“U042-050”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+470.589941+61.07399
