UR050-010
UR050-010
    TRIPPLITE
    UR050-010
UR050-010 数据手册
Universal Reversible USB 2.0 Cable (Reversible A-M to 5Pin Micro B-M), 10 ft. (3.05 m) MODEL NUMBER: UR050-010 Highlights ● Next Generation USB Digital Device Connector ● Provides both Data and Power transfers ● USB 2.0 480Mbps Transfer rates ● Universal / Reversible "A" Male to Micro-B Male System Requirements ● Digital devices that use the USB Micro-B Female socket Package Includes ● Universal / Reversible "A" connector allows plugging in any direction Description Tripp Lite UR050-010, 10-ft. (3.05 m) USB 2.0 A to Micro-B cable, features a Universal / Reversible "A" connector, which takes the guesswork out of which way to position the "A" connector for plugging. MicroUSB is the next generation of USB connector that will be found on Cell Phones, PDA's, USB On-the-Go ( OTG ) devices, Digital Cameras, and more. Smaller and more durable ( 10,000 insertion cycles ) than the existing mini-B connectors, the Micro-USB will also handle Power transfers, as well as Data. The USB Implementers Forum ( USB-IF ) has designed the Micro-USB to eliminate many of the proprietary Mini connectors found on different manufacturers digital devices, and it will be the standard USB connection on phones from the major cell phone manufacturers. USB 2.0 rated cable handles 480Mbps data transfer rates. Features ● USB Universal / Reversible A Male to Micro-B Male ● Available in 3-ft. (0.91 m), 6-ft. (1.83 m), and 10-ft. (3.05 m) lengths ● 480Mbps USB 2.0 Data Transfer Rates ● Data and Power transference Specifications OVERVIEW UPC Code 037332179579 Technology USB 2.0 (High Speed) USB Cable Type Passive PHYSICAL Cable Jacket Color Black 1/2 10-ft. (3.05 m) USB2.0 Universal / Reversible A to Micro-USB B Device Cable (A Male to MicroB Male) Cable Length (ft.) 10 Cable Length (m) 3.05 Shipping Dimensions (hwd / in.) 0.25 x 6.00 x 7.00 Shipping Dimensions (hwd / cm) 0.64 x 15.24 x 17.78 Shipping Weight (lbs.) 0.05 Shipping Weight (kg) 0.02 ENVIRONMENTAL Operating Temperature Range 14 to 122 F (-10 to 50 C) Storage Temperature Range 5 to 140 F (-15 to 60 C) Operating Humidity Range 0% to 90% RH, Non-Condensing Storage Humidity Range 0% to 90% RH, Non-Condensing CONNECTIONS Side A - Connector 1 REVERSIBLE USB A (MALE) Side B - Connector 1 MICRO-USB B (MALE) WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2022 Tripp Lite. All rights reserved. All product and company names are trademarks or registered trademarks of their respective holders. Use of them does not imply any affiliation with or endorsement by them. Tripp Lite has a policy of continuous improvement. Specifications are subject to change without notice. Tripp Lite uses primary and third-party agencies to test its products for compliance with standards. See a list of Tripp Lite's testing agencies: https://www.tripplite.com/products/product-certification-agencies 2/2
UR050-010 价格&库存
很抱歉,暂时无法提供与“UR050-010”相匹配的价格&库存,您可以联系我们找货
