4
D
3
2
ASSY. P/N: USB-3000-CAX003
USB-3000-CAX006
USB-3000-CAX012
2
"H"= HOST TO HOST
OR
"P"= HOST TO PERIPHERAL
ZONE REV
ALL N/C
NOTES, UNLESS OTHERWISE SPECIFIED:
1
2
O
1
INSTALL CONNECTORS AS REQUIRED
2
STRIP AND TIN PER IEC-J-STD-001
3
USE STRAIN RELIEF AS REQUIRED
4
INSTALL BLACK HEAT SHRINK AS REQUIRED
B
1
2
OB
D
"A" BILL OF MATERIALS, H-H
ITEM QTY PART NUMBER DESCRIPTION
1 A/R 580R101
CICOIL BULK
CABLE
2
2 A-USBPA-3-R* ASSMANN
USB TYPE A
CONNECTOR
3
1 PRODUCTION BLACK HEAT
C
PREFERENCE SHRINK
(-55°C TO
+135°C)
5
CONDUCTORS: ULTRA FLEXIBLE,
FINELY STRANDED, TINNED COPPER
6
SHIELDING: ULTRA FLEXIBLE, BRAIDED
SHIELDS,WITH 90% NOMINAL COVERAGE
7
MINIMUM BEND RADIUS: 6X CABLE HEIGHT FOR
INTERMEDIATE FLEX;
10X CABLE HEIGHT FOR CONTINUOUS FLEX
8
FLEX LIFE: 10,000,000 CYCLES NOMINAL
9
OUTER JACKET DUROMETER RATING:
65 (SHORE A)
C
BY
RR
CROSS SECTION VIEW
OF THE CABLE
P/N: 580R101
WIDTH .62"
HEIGHT .18"
LENGTH IN FEET
A
3
1
REVISION HISTORY
DESCRIPTION
DATE
12/04/12
INITIAL RELEASE
10 TEMPERATURE RATING FOR CABLE:
-65°C TO +165°C
TEMPERATURE RATING FOR FINISHED ASSEMBLY:
-20°C TO +85°C
11 OUTER JACKET DIELECTRIC STRENGTH:
450 VOLTS/MILS (17.7 kv/mm)
"B" BILL OF MATERIALS, H-P
1 A/R 580R101
CICOIL BULK
CABLE
2
1 A-USBPA-3-R* ASSMANN
USB TYPE A
CONNECTOR
1 A-USBPB-3-R* ASSMANN
3
USB TYPE B
CONNECTOR B
4
PREFERENCE SHRINK
(-55°C TO
+135°C)
12 * OR EQUIVALENT
THESE DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF
CICOIL LLC AND ARE ISSUED IN STRICT CONFIDENCE AND SHALL NOT
BE REPRODUCED OR COPIED OR USED AS THE BASIS FOR THE
MANUFACTURE OR SALE 0F EQUPMENT WITHOUT PERMISSION.
STANDARD TOLERANCES
UNLESS OTHERWISE NOTED
DIMENSIONS ARE IN INCHES
.X+/- 0.5
.XX+/-0.05
.XXX+/-0.005
ANGLES +/- 5 DEG
[MM]
A
VIEW PROJECTION
DATE
SIGNATURE
24960 AVENUE TIBBITTS, VALENCIA, CA 91355 www.cicoil.com 661-295-1295
DRAWN:
rruiz
12/4/2012
JOHN PALAHNUK
8/21/2013
TITLE
CHECK
USB CABLE ASSEMBLY
ENGINEER
JOHN PALAHNUK
8/21/2013
CAGE CODE
DASH
NO
QTY
REQD
NEXT
ASSEMBLY
FINAL
ASSEMBLY
MATERIAL:
19476
SIZE
A
DRAWING NUMBER
REVISION
USB-3000-CAXXXX
N/C
APPLICATION
SCALE
DO NOT SCALE DRAWING
4
3
2
FILE: USB-3000-CAXXXX (C).idw
1
SHEET 1 OF 1
很抱歉,暂时无法提供与“USB-3000-CAP003”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+1123.867891+145.40231
