UR050-06N-WH
UR050-06N-WH
    TRIPPLITE
    USBCABLE
UR050-06N-WH 数据手册
USB-A to USB Micro-B Cable (M/M) - USB 2.0, White, 6-in. (15.24 cm) MODEL NUMBER: UR050-06N-WH Highlights ● Supports USB 2.0 speeds up to 480 Mbps to ensure efficient charging and data transfers ● Integral strain relief helps cable move freely without stress or cracking ● Recommended for streaming video and other applications that require a reliable, clear signal Applications ● Charge and sync your smartphone or other Micro-B device from a USB computer or wall charger ● Transfer data between a hard drive or flash drive and your computer System Requirements USB cable with reversible USB-A plug connects a smartphone or other Micro-B device to the USB port on your computer or charger. Features ● Device or charger with USB-A port ● Device with USB Micro-B port Package Includes The UR050-06N-WH USB sync/charge cable (M/M) connects your smartphone, external hard drive, digital camera or other USB Micro-B device to a computer, car charger or wall charger. It allows you to charge and power your Micro-B device, as well as sync and transfer data at USB 2.0 speeds up to 480 Mbps. It's ideal for streaming audio/video and other high-end applications that require reliable, clear transmission free of line noise and other interference. The reversible USB-A plug ensures a successful connection the first time, every time. Specifications OVERVIEW UPC Code 037332182296 Technology USB 2.0 (High Speed) PHYSICAL Color White Cable Length (ft.) 0.5 Cable Length (m) 0.15 Cable Length (in.) 6 Cable Length (cm) 15.24 Shipping Dimensions (hwd / in.) 0.25 x 0.25 x 4.00 Shipping Dimensions (hwd / cm) 0.64 x 0.64 x 10.16 1/2 ● UR050-06N-WH USB-A to USB Micro-B Cable (M/M), White, 6 in. Shipping Weight (lbs.) 0.04 Shipping Weight (kg) 0.02 ENVIRONMENTAL Operating Temperature Range -10/+75° C (14 to 167° F) Storage Temperature Range -20/+80° C (-4 to 176° F) CONNECTIONS Side A - Connector 1 REVERSIBLE USB A (MALE) Side B - Connector 1 MICRO-USB B (MALE) WARRANTY Product Warranty Period (Worldwide) Lifetime limited warranty © 2022 Tripp Lite. All rights reserved. All product and company names are trademarks or registered trademarks of their respective holders. Use of them does not imply any affiliation with or endorsement by them. Tripp Lite has a policy of continuous improvement. Specifications are subject to change without notice. Tripp Lite uses primary and third-party agencies to test its products for compliance with standards. See a list of Tripp Lite's testing agencies: https://www.tripplite.com/products/product-certification-agencies 2/2
UR050-06N-WH 价格&库存
很抱歉,暂时无法提供与“UR050-06N-WH”相匹配的价格&库存,您可以联系我们找货
