UR030-006-SLIM
UR030-006-SLIM
    TRIPPLITE
    6'USBATOMINI-BCABLEM/M
UR030-006-SLIM 数据手册
Universal Reversible USB 2.0 Cable (Reversible A to 5Pin Mini B M/M), 6-ft. MODEL NUMBER: UR030-006-SLIM Highlights ● Super Slim design....25% thinner than standard USB MiniB cables ● Universal / Reversible A connector eliminates guesswork as to connector orientation ● Supports USB 2.0 data transfer rates up to 480Mbps ● Connects to Cameras, PDA's, etc with Mini-B 5-Pin connectors System Requirements ● Any USB device requiring a USB cable with 5-Pin Mini-B connector ● USB 2.0 performance only when used with USB 2.0 device and USB 2.0 controller Package Includes ● Description Tripp Lite's UR030-006-SLIM 6-ft. USB 2.0 A to 5-Pin Mini-B device cable features a Super Slim design that is 25% thinner than standard USB Mini-B cables. It also includes a Universal / Reversible "A" connector, which takes the guesswork out of which way to position the "A" connector for plugging. It supports USB 2.0 data transfer rates up to 480Mbps, and is backward compatible with USB 1.1. Connects a Digital camera, PDA, Cell Phone, or other device with a 5-Pin Mini-B connector to a USB port on a computer or hub. All Tripp Lite USB 2.0 cabling includes superior foil shielding for reliable, error-free data communications. Features nickel plated connectors and gold plated copper contacts for superior conductivity. The cable is manufactured with molded connectors and integral strain relief for extra durability and long life. Features ● Super Slim design....25% thinner than standard USB Mini-B cables ● Universal / Reversible A connector eliminates guess-work as to connector orientation ● Supports USB 2.0 data transfer rates up to 480Mbps ● Connects to Cameras, PDA's, and other devices with 5-Pin Mini-B connectors ● Premium double-shielded cables with tinned copper braid and aluminum Mylar foil ● Nickel plated connectors and gold plated copper contacts for superior conductivity. ● Molded connectors and integral strain relief for extra durability and long life. Specifications OVERVIEW UPC Code 037332188144 1/2 6-ft. USB 2.0 Universal / Reversible A to 5-Pin Mini-B Super Slim Device Cable Technology USB 2.0 (High Speed) PHYSICAL Color Black Cable Length (ft.) 6 Cable Length (m) 1.83 Shipping Dimensions (hwd / in.) 9.00 x 7.00 x 0.50 Shipping Dimensions (hwd / cm) 22.86 x 17.78 x 1.27 Shipping Weight (lbs.) 0.13 Shipping Weight (kg) 0.06 ENVIRONMENTAL Operating Temperature Range -10 to 75° C (14 to 167° F) Storage Temperature Range -20 to 80° C (-4 to 176° F) CONNECTIONS Side A - Connector 1 REVERSIBLE USB A (MALE) Side B - Connector 1 USB MINI-B 5-PIN (MALE) WARRANTY Product Warranty Period (Worldwide) Lifetime limited warranty © 2022 Tripp Lite. All rights reserved. All product and company names are trademarks or registered trademarks of their respective holders. Use of them does not imply any affiliation with or endorsement by them. Tripp Lite has a policy of continuous improvement. Specifications are subject to change without notice. Tripp Lite uses primary and third-party agencies to test its products for compliance with standards. See a list of Tripp Lite's testing agencies: https://www.tripplite.com/products/product-certification-agencies 2/2
UR030-006-SLIM
物料型号:UR030-006-SLIM
器件简介:Tripp Lite的USB 2.0 A到5-Pin Mini-B设备电缆,具有超薄设计,比标准USB Mini-B电缆薄25%,带有通用/可逆“A”连接器,消除了插入方向的猜测。
引脚分配:Side A-Connector 1为可逆USB A(公),Side B-Connector 1为USB MINI-B 5-PIN(公)。
参数特性:支持USB 2.0数据传输速率高达480Mbps,与USB 1.1向后兼容。电缆长度为6英尺(1.83米)。
功能详解:连接数字相机、PDA、手机或其他带有5-Pin Mini-B连接器的设备到计算机或集线器上的USB端口。所有Tripp Lite USB 2.0电缆都包括优越的箔屏蔽,以实现可靠、无误的数据通信。
应用信息:适用于任何需要带有5-Pin Mini-B连接器的USB电缆的USB设备。
封装信息:黑色,带有镍镀连接器和金镀铜接触点,以实现优越的导电性。电缆采用模制连接器和整体应力缓解,以增加耐用性和寿命。
UR030-006-SLIM 价格&库存
很抱歉,暂时无法提供与“UR030-006-SLIM”相匹配的价格&库存,您可以联系我们找货
