Universal Reversible USB 2.0 Extension Cable
(Up / Down Angle Reversible A to A M/F), 6-ft.
MODEL NUMBER: UR024-006-UDA
Highlights
Universal, Up / Down Reversible
A-Male plugs in any direction
Extend distances of USB 2.0
cables with this extension cable
Supports faster data transfer
rates (1.5 to 480 Mbps) for low
speed and high speed devices,
especially multimedia
applications
Premium double-shielded
cables with tinned copper braid
and aluminum mylar foil feature
twisted 28/24 AWG data lines
Gold plated contacts provide
superior conductivity
System Requirements
Any USB device requiring a
USB cable
USB 2.0 performance only when
used with USB 2.0 device and
USB 2.0 controller
Up / Down Angle Reversible USB "A" connector plugs in any direction
Package Includes
Description
This 6-ft USB extension cable features an Up / Down Angle Reversible A-Male connector, and is
manufactured using USB 2.0 cable. Up / Down Angle Reversible connector allows the cable to be plugged
in any direction. This cable is backwards compatible and can also be used with the older USB 1.1 cables.
Made with superior foil shielding for reliable error-free data communications. Features nickel plated
connectors and gold plated copper contacts for superior conductivity. The cable is manufactured with
molded connectors and integral strain relief for extra durability and long life. The significantly faster data
transfer rates of USB 2.0 (up to 480 Mbps) makes it perfect for multimedia applications.
Features
6-ft., USB 2.0 Up / Down Angle Reversible A-Male to A-Female Extension Cable
USB 2.0 compliant, to 480Mbps transfer rates
Backward compatible with previous USB generations
Gold plated contacts and molded ends provide a lifetime of use
28AWG Data Pair, 24AWG Power pair
Specifications
OVERVIEW
UPC Code
037332185358
Technology
USB 2.0 (High Speed)
PHYSICAL
1/2
USB 2.0 A-Male to A-Female
Extension Cable - 6-ft.
Color
Black
Cable Length (ft.)
6
Cable Length (m)
1.83
Shipping Dimensions (hwd / in.)
9.00 x 7.00 x 0.50
Shipping Dimensions (hwd / cm)
22.86 x 17.78 x 1.27
Shipping Weight (lbs.)
0.15
Shipping Weight (kg)
0.07
ENVIRONMENTAL
Operating Temperature Range
-10/+75° C (14 to 167° F)
Storage Temperature Range
-20/+80° C (-4 to 176° F)
CONNECTIONS
Side A - Connector 1
REVERSIBLE USB A (MALE)
Side B - Connector 1
USB A (FEMALE)
WARRANTY
Product Warranty Period
(Worldwide)
Lifetime limited warranty
© 2022 Tripp Lite. All rights reserved. All product and company names are trademarks or registered trademarks of their respective holders. Use of them does
not imply any affiliation with or endorsement by them. Tripp Lite has a policy of continuous improvement. Specifications are subject to change without notice.
Tripp Lite uses primary and third-party agencies to test its products for compliance with standards. See a list of Tripp Lite's testing agencies:
https://www.tripplite.com/products/product-certification-agencies
2/2
很抱歉,暂时无法提供与“UR024-006-UDA”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+4.764221+0.57525
