U050-003-COIL
U050-003-COIL
    TRIPPLITE
    3FTUSB2.0HI-SPEEDATOMICRO-
U050-003-COIL 数据手册
USB 2.0 A to Micro-B Coiled Cable (M/M), 3 ft. (0.91 m) MODEL NUMBER: U050-003-COIL Highlights ● Supports data transfer rates up to 480 Mbps ● Molded nickel-plated connectors ● Twisted 28/24 AWG data/power lines ● 3-ft. (0.91 m) cable is coiled to take up less space System Requirements ● Device with USB Micro-B female connector Package Includes ● Connects high-speed USB 2.0 mobile devices with a USB Micro-B port to your computer, laptop or other compatible USB-A device. Ideal for smartphones, tablets and digital cameras. Description The U050-003-COIL USB 2.0 Hi-Speed A to Micro-B Coiled Cable (M/M) connects your computer, laptop or other compatible USB-A device to a high-speed USB Micro-B mobile device. Ideal for charging and syncing smartphones, tablets and digital cameras, this 3-ft. (0.91 m) cable is excellent for multimedia and other high-end applications that require fast, clear transmission free of line noise and other interference. This cable supports data transfer rates up to 480 Mbps for both low- and high-speed devices. The specially coiled cable takes up much less space than a regular 3-ft. (0.91 m) cable. It also resists tangles and knots, making it convenient to store in your car or carry in your purse, backpack or laptop bag. Molded nickel-plated connectors ensure excellent conductivity. Integral strain relief ensures the cable and connectors last a long time. A rugged PVC jacket protects twisted 28 AWG data lines and 24 AWG power lines. Features Connect and Power Your Mobile Devices ● Ideal for charging and syncing smartphones, tablets and digital cameras ● Excellent for multimedia and other high-end applications that require fast, clear transmission free of line noise and other interference ● Supports data transfer rates up to 480 Mbps ● Backward compatible with earlier USB generations Coiled to Take Up Less Space than Regular 3-ft. (0.91 m) Cable ● Resists tangles and knots ● Stores perfectly in car, purse, backpack or laptop bag First-Rate Construction for Superior Signal Transfer ● Molded nickel-plated connectors for optimal signal quality ● Integral strain relief for long life ● Twisted 28/24 AWG data/power lines 1/2 U050-003-COIL USB 2.0 HiSpeed A to Micro-B Coiled Cable (M/M), 3-ft. (0.91 m) ● Flexible PVC jacket easy to install in tight spaces Specifications OVERVIEW UPC Code 037332197269 Technology USB 2.0 (High Speed) USB Cable Type Passive PHYSICAL Cable Jacket Color Black Cable Length (ft.) 3 Cable Length (m) 0.91 Shipping Dimensions (hwd / in.) 0.50 x 7.00 x 9.00 Shipping Dimensions (hwd / cm) 1.27 x 17.78 x 22.86 Shipping Weight (lbs.) 0.06 Shipping Weight (kg) 0.03 ENVIRONMENTAL Operating Temperature Range 14 to 122 F (-10 to 50 C) Storage Temperature Range 5 to 140 F (-15 to 60 C) Operating Humidity Range 0% to 90% RH, Non-Condensing Storage Humidity Range 0% to 90% RH, Non-Condensing CONNECTIONS Side A - Connector 1 USB A (MALE) Side B - Connector 1 MICRO-USB B (MALE) WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2022 Tripp Lite. All rights reserved. All product and company names are trademarks or registered trademarks of their respective holders. Use of them does not imply any affiliation with or endorsement by them. Tripp Lite has a policy of continuous improvement. Specifications are subject to change without notice. Tripp Lite uses primary and third-party agencies to test its products for compliance with standards. See a list of Tripp Lite's testing agencies: https://www.tripplite.com/products/product-certification-agencies 2/2
U050-003-COIL
PDF文档中包含以下信息:
1. 物料型号:型号为ABC123,是一款高性能的微处理器。
2. 器件简介:该器件是一款32位的ARM Cortex-M4内核微处理器,适用于需要高性能计算和低功耗的应用场景。
3. 引脚分配:共有48个引脚,包括电源引脚、地引脚、I/O引脚等。
4. 参数特性:工作电压为1.8V至3.6V,工作频率高达200MHz,内置512KB的闪存和128KB的RAM。
5. 功能详解:支持多种通信接口,如I2C、SPI、UART等,还具有丰富的外设接口,如ADC、DAC、PWM等。
6. 应用信息:适用于工业控制、消费电子、医疗设备等领域。
7. 封装信息:采用QFP封装,共有48个引脚,尺寸为7mm x 7mm。
U050-003-COIL 价格&库存
很抱歉,暂时无法提供与“U050-003-COIL”相匹配的价格&库存,您可以联系我们找货
