U050-006-COIL
U050-006-COIL
    TRIPPLITE
    U050-006-COIL
U050-006-COIL 数据手册
USB 2.0 A to Micro-B Coiled Cable (M/M), 6 ft. (1.83 m) MODEL NUMBER: U050-006-COIL Highlights ● Supports data transfer rates up to 480 Mbps ● Molded nickel-plated connectors ● Twisted 28/24 AWG data/power lines ● 6-ft. (1.83 m) cable is coiled to take up less space System Requirements ● Digital device with USB Micro-B female connector Package Includes ● Connects high-speed USB 2.0 mobile devices with a USB Micro-B port to your computer, laptop or other compatible USB-A device. Ideal for smartphones, tablets and digital cameras. Description The U050-006-COIL USB 2.0 Hi-Speed A to Micro-B Coiled Cable (M/M) connects your computer, laptop or other compatible USB-A device to a high-speed USB Micro-B mobile device. Ideal for charging and syncing smartphones, tablets and digital cameras, this 6-ft. (1.83 m) cable is excellent for multimedia and other high-end applications that require fast, clear transmission free of line noise and other interference. This cable supports data transfer rates up to 480 Mbps for both low- and high-speed devices. The specially coiled cable takes up much less space than a regular 6-ft. (1.83 m) cable. It also resists tangles and knots, making it convenient to store in your car or carry in your purse, backpack or laptop bag. Molded nickel-plated connectors ensure excellent conductivity. Integral strain relief ensures the cable and connectors last a long time. A rugged PVC jacket protects twisted 28 AWG data lines and 24 AWG power lines. Features Connect and Power Your Mobile Devices ● Ideal for charging and syncing smartphones, tablets and digital cameras ● Excellent for multimedia and other high-end applications that require fast, clear transmission free of line noise and other interference ● Supports data transfer rates up to 480 Mbps ● Backward compatible with earlier USB generations Coiled to Take Up Less Space than Regular 6-ft. (1.83 m) Cable ● Resists tangles and knots ● Stores perfectly in car, purse, backpack or laptop bag First-Rate Construction for Superior Signal Transfer ● Molded nickel-plated connectors for optimal signal quality ● Integral strain relief for long life ● Twisted 28/24 AWG data/power lines 1/2 U050-006-COIL USB 2.0 HiSpeed A to Micro-B Coiled Cable (M/M), 6-ft. (1.83 m) ● Flexible PVC jacket easy to install in tight spaces Specifications OVERVIEW UPC Code 037332197221 Technology USB 2.0 (High Speed) USB Cable Type Passive PHYSICAL Cable Jacket Color Black Cable Length (ft.) 6 Cable Length (m) 1.83 Shipping Dimensions (hwd / in.) 9.00 x 7.00 x 5.00 Shipping Dimensions (hwd / cm) 22.86 x 17.78 x 12.70 Shipping Weight (lbs.) 0.20 Shipping Weight (kg) 0.09 ENVIRONMENTAL Operating Temperature Range 14 to 122 F (-10 to 50 C) Storage Temperature Range 5 to 140 F (-15 to 60 C) Operating Humidity Range 0% to 90% RH, Non-Condensing Storage Humidity Range 0% to 90% RH, Non-Condensing CONNECTIONS Side A - Connector 1 USB A (MALE) Side B - Connector 1 MICRO-USB B (MALE) WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2022 Tripp Lite. All rights reserved. All product and company names are trademarks or registered trademarks of their respective holders. Use of them does not imply any affiliation with or endorsement by them. Tripp Lite has a policy of continuous improvement. Specifications are subject to change without notice. Tripp Lite uses primary and third-party agencies to test its products for compliance with standards. See a list of Tripp Lite's testing agencies: https://www.tripplite.com/products/product-certification-agencies 2/2
U050-006-COIL 价格&库存
很抱歉,暂时无法提供与“U050-006-COIL”相匹配的价格&库存,您可以联系我们找货
