USB 2.0 A to B Coiled Cable (M/M), 10 ft. (3.05 m)
Highlights
Supports data transfer rates up
to 480 Mbps
Molded nickel-plated connectors
Twisted 28/24 AWG data/power
lines
10-ft. (3.05 m) cable is coiled to
take up less space
MODEL NUMBER: U022-010-COIL
System Requirements
Device requiring USB cable
USB 2.0 performance only when
used with USB 2.0 device and
USB 2.0 controller
Package Includes
Connects high-speed USB 2.0 peripherals with a USB-B port to your computer, laptop or other compatible
USB-A device. Ideal for printers and scanners.
Description
The U022-010-COIL USB 2.0 Hi-Speed A/B Coiled Cable (M/M) connects your computer, laptop or other
compatible USB-A device to a USB-B peripheral, such as printers and scanners. This 10-ft. (3.05 m) cable
supports data transfer rates up to 480 Mbps for both low- and high-speed devices, including multimedia
applications.
The specially coiled cable takes up much less space than a regular 10-ft. (3.05 m) cable. It also resists
tangles and knots, making it convenient to store in your car or carry in your purse, backpack or laptop bag.
Molded nickel-plated connectors ensure excellent conductivity. Integral strain relief ensures the cable and
connectors last a long time. A rugged PVC jacket protects twisted 28 AWG data lines and 24 AWG power
lines.
Features
Connect Your USB Type-B Peripherals to Your Computer
● Ideal for printers and scanners
Supports data transfer rates up to 480 Mbps
Backward compatible with earlier USB generations
Coiled to Take Up Less Space than Regular 10-ft. (3.05 m) Cable
● Resists tangles and knots
Stores perfectly in car, purse, backpack or laptop bag
First-Rate Construction for Superior Signal Transfer
● Molded nickel-plated connectors for optimal signal quality
Integral strain relief for long life
Twisted 28/24 AWG data/power lines
Flexible PVC jacket easy to install in tight spaces
Specifications
1/2
U022-010-COIL USB 2.0 HiSpeed A/B Coiled Cable (M/M),
10-ft. (3.05 m)
OVERVIEW
UPC Code
037332197283
Technology
USB 2.0 (High Speed)
USB Cable Type
Passive
PHYSICAL
Cable Jacket Color
Black
Cable Length (ft.)
10
Cable Length (m)
3.05
Shipping Dimensions (hwd / in.)
0.50 x 7.00 x 9.50
Shipping Dimensions (hwd / cm)
1.27 x 17.78 x 24.13
Shipping Weight (lbs.)
0.14
Shipping Weight (kg)
0.06
ENVIRONMENTAL
Operating Temperature Range
14 to 122 F (-10 to 50 C)
Storage Temperature Range
5 to 140 F (-15 to 60 C)
Operating Humidity Range
0% to 90% RH, Non-Condensing
Storage Humidity Range
CONNECTIONS
Side A - Connector 1
USB A (MALE)
Side B - Connector 1
USB B (MALE)
STANDARDS & COMPLIANCE
Product Compliance
RoHS
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
Lifetime limited warranty
© 2022 Tripp Lite. All rights reserved. All product and company names are trademarks or registered trademarks of their respective holders. Use of them does
not imply any affiliation with or endorsement by them. Tripp Lite has a policy of continuous improvement. Specifications are subject to change without notice.
Tripp Lite uses primary and third-party agencies to test its products for compliance with standards. See a list of Tripp Lite's testing agencies:
https://www.tripplite.com/products/product-certification-agencies
2/2
很抱歉,暂时无法提供与“U022-010-COIL”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+55.944081+6.94131
- 10+50.6075510+6.27918
- 25+47.8057725+5.93154
- 50+46.6411450+5.78704
- 100+44.30927100+5.49771
- 250+39.64497250+4.91898
- 500+37.31291500+4.62963
- 1000+32.648801000+4.05093
- 2500+31.016352500+3.84838
