UR050-003-RAB
UR050-003-RAB
    TRIPPLITE
    3'USBATOMICROBCABLEM/M
UR050-003-RAB 数据手册
Universal Reversible USB 2.0 Cable (Reversible A to Right-angle 5Pin Micro B M/M), 3 ft. (0.91 m) MODEL NUMBER: UR050-003-RAB Highlights ● Universal / Reversible A connector eliminates guesswork as to connector orientation ● Right-Angle Micro B connector ideal in situations where space is at a premium, and reduces stress / excessive bending on the cable ● Next Generation USB Digital Device Connector ● Provides both Data and Power transfers ● USB 2.0 480Mbps Transfer rates ● Universal / Reversible "A" Male to Micro-B Male System Requirements ● Package Includes Universal / Reversible "A" connector allows plugging in any direction ● Description Tripp Lite UR050-003-RAB, 3-ft. (0.91 m) USB 2.0 A to Right-Angle Micro-B cable, features a Universal / Reversible "A" connector, which takes the guesswork out of which way to position the "A" connector for plugging. Furthermore, the Right-Angle Micro B connector is ideal for situations where space is at a premium, and reduces stress / excessive bending on the cable. Micro-USB is the next generation of USB connector that will be found on Cell Phones, PDA's, USB On-the-Go ( OTG ) devices, Digital Cameras, and more. Smaller and more durable ( 10,000 insertion cycles ) than the existing mini-B connectors, the Micro-USB will also handle Power transfers, as well as Data. The USB Implementers Forum ( USB-IF ) has designed the Micro-USB to eliminate many of the proprietary Mini connectors found on different manufacturers digital devices, and it will be the standard USB connection on phones from the major cell phone manufacturers. USB 2.0 rated cable handles 480Mbps data transfer rates. Features ● Universal / Reversible A connector eliminates guess-work as to connector orientation ● Right-Angle Micro B connector ideal in situations where space is at a premium, and reduces stress / excessive bending on the cable ● 480Mbps USB 2.0 Data Transfer Rates ● Data and Power transference Specifications OVERVIEW UPC Code 037332182432 Technology USB 2.0 (High Speed) Digital devices that use the USB Micro-B Female socket 1/2 3-ft. (0.91 m) USB2.0 Universal / Reversible A to Right-Angle Micro-USB B Device Cable (A Male to Micro-B Male) PHYSICAL Color Black Cable Length (ft.) 3 Cable Length (m) 0.91 Shipping Dimensions (hwd / in.) 0.25 x 4.00 x 8.00 Shipping Dimensions (hwd / cm) 0.64 x 10.16 x 20.32 Shipping Weight (lbs.) 0.05 Shipping Weight (kg) 0.02 ENVIRONMENTAL Operating Temperature Range -10/+75° C (14 to 167° F) Storage Temperature Range -20/+80° C (-4 to 176° F) CONNECTIONS Side A - Connector 1 REVERSIBLE USB A (MALE) Side B - Connector 1 MICRO-USB B (MALE) WARRANTY Product Warranty Period (Worldwide) Lifetime limited warranty © 2022 Tripp Lite. All rights reserved. All product and company names are trademarks or registered trademarks of their respective holders. Use of them does not imply any affiliation with or endorsement by them. Tripp Lite has a policy of continuous improvement. Specifications are subject to change without notice. Tripp Lite uses primary and third-party agencies to test its products for compliance with standards. See a list of Tripp Lite's testing agencies: https://www.tripplite.com/products/product-certification-agencies 2/2
UR050-003-RAB 价格&库存
很抱歉,暂时无法提供与“UR050-003-RAB”相匹配的价格&库存,您可以联系我们找货
