U024-005-DSK1
U024-005-DSK1
    TRIPPLITE
    U024-005-DSK1
U024-005-DSK1 数据手册
1-Port USB 2.0 Desktop Extension Cable (M/F), 5 ft. (1.52 m) MODEL NUMBER: U024-005-DSK1 Highlights ● Supports data transfer rates up to 480 Mbps ● Premium foil and braid shielding ● Backward compatible with earlier USB generations ● Flexible PVC jacket for easy installation in tight spaces ● Black padded non-sliding base System Requirements ● Computer, laptop or other device with USB-A port Package Includes ● Extends your desktop computer’s existing USB-A port up to 5 ft. away. Ideal for connecting external hard drives, thumb drives, digital cameras and other USB-A devices. Features Extends an Existing USB-A Port an Extra 5 ft. ● Move a hard-to-reach USB port within easy access ● Ideal for connecting external hard drives, thumb drives, digital cameras and other USB-A devices ● Supports data transfer rates up to 480 Mbps ● Backward compatible with earlier USB generations First-Rate Construction for Superior Signal Transfer ● Premium foil and braid shielding for EMI/RFI noise protection ● Molded nickel-plated connectors for optimal signal quality ● Integral strain relief for long life ● Flexible PVC jacket for easy installation in tight spaces ● Black padded non-sliding base Specifications OVERVIEW UPC Code 037332199331 Technology USB; USB 2.0 (High Speed) USB Cable Type Passive INPUT 1/3 U024-005-DSK1 1-Port USB 2.0 Hi-Speed Desktop Extension Cable (M/F), 5 ft. Maximum Input Amps 1 CHARGING Total Charging Watts 5 PHYSICAL Material of Construction PVC Cable Jacket Color Black Cable Jacket Material PVC Cable Jacket Rating VW-1 Cable Outer Diameter (OD) 3.5mm Cable Length (ft.) 5 Cable Length (m) 1.52 Unit Packaging Type Polybag ENVIRONMENTAL Operating Temperature Range 32 to 104 F (0 to 40 C) Storage Temperature Range 14 to 131 F (-10 to 55 C) Relative Humidity 5% to 90% RH, Non-Condensing Operating Humidity Range 0% to 90% RH, Non-Condensing Storage Humidity Range 0% to 90% RH, Non-Condensing Power Provided to Connected Device(s) 5W (5V/1A) CONNECTIONS Side A - Connector 1 USB A (MALE) Side B - Connector 1 USB A (FEMALE) Connector Plating Nickel Contact Plating Gold FEATURES & SPECIFICATIONS Data Transfer Rate 480 Mbps USB Specification USB 2.0 (up to 480 Mbps) STANDARDS & COMPLIANCE Product Compliance RoHS; REACH WARRANTY & SUPPORT 2/3 Product Warranty Period (Worldwide) Lifetime limited warranty © 2022 Tripp Lite. All rights reserved. All product and company names are trademarks or registered trademarks of their respective holders. Use of them does not imply any affiliation with or endorsement by them. Tripp Lite has a policy of continuous improvement. Specifications are subject to change without notice. Tripp Lite uses primary and third-party agencies to test its products for compliance with standards. See a list of Tripp Lite's testing agencies: https://www.tripplite.com/products/product-certification-agencies 3/3
U024-005-DSK1 价格&库存
很抱歉,暂时无法提供与“U024-005-DSK1”相匹配的价格&库存,您可以联系我们找货
