USB 3.0 SuperSpeed Extension Cable (A M/F),
Black, 6-in. (15.24 cm)
MODEL NUMBER: U324-06N-BK
Highlights
Supports data transfer rates up
to 5 Gbps
Bi-directional interface allows
data to flow both directions
Backward compatible with
previous USB generations
Double-shielded protection
against EMI/RFI
Molded nickel-plated conductors
Package Includes
Extends your existing USB 3.0 connection by 6 in.
Features
Extend an Existing USB 3.0 Cable an Extra 6 in.
● Female USB-A connector attaches to current USB 3.0 cable
Enjoy SuperSpeed Transfer Rates in High-End Applications
● Supports data transfer rates up to 5 Gbps—10X the speed of USB 2.0
Bi-directional interface allows data to flow both directions at the same time, increasing theoretical
bandwidth by 10X
Premium Construction for Superior Signal Transfer
● Premium foil and braid shielding blocks EMI/RFI interference
Molded nickel-plated connectors ensure excellent connectivity
Integral strain relief for cable and connectors’ long life
Twisted 28/24 AWG data/power lines
Rugged PVC jacket
Specifications
OVERVIEW
UPC Code
037332193513
USB Cable Type
Passive
PHYSICAL
1/2
U324-06N-BK USB 3.0
SuperSpeed Type-A Extension
Cable (M/F), Black, 6 in.
Material of Construction
PVC
Cable Jacket Color
Black
Cable Jacket Rating
VW-1
Cable Outer Diameter (OD)
5.5MM
Cable Length (ft.)
0.5
Cable Length (m)
0.15
Cable Length (in.)
6
Cable Length (cm)
15.24
Shipping Dimensions (hwd / in.)
9.00 x 7.00 x 0.50
Shipping Dimensions (hwd / cm)
22.86 x 17.78 x 1.27
Shipping Weight (lbs.)
0.06
Shipping Weight (kg)
0.03
ENVIRONMENTAL
Operating Temperature Range
14 to 140 F (-10 to 60 C)
Storage Temperature Range
-4 to 185 F (-20 to 85 C)
Relative Humidity
10% to 85%, Non-Condensing
CONNECTIONS
Side A - Connector 1
USB 3.0 A (MALE)
Side B - Connector 1
USB 3.0 A (FEMALE)
Connector Plating
Nickel
Contact Plating
Gold
FEATURES & SPECIFICATIONS
USB Specification
USB 3.0 (up to 5 Gbps)
STANDARDS & COMPLIANCE
Product Compliance
RoHS; CE (Europe); REACH; FCC (USA)
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
Lifetime limited warranty
© 2022 Tripp Lite. All rights reserved. All product and company names are trademarks or registered trademarks of their respective holders. Use of them does
not imply any affiliation with or endorsement by them. Tripp Lite has a policy of continuous improvement. Specifications are subject to change without notice.
Tripp Lite uses primary and third-party agencies to test its products for compliance with standards. See a list of Tripp Lite's testing agencies:
https://www.tripplite.com/products/product-certification-agencies
2/2
很抱歉,暂时无法提供与“U324-06N-BK”相匹配的价格&库存,您可以联系我们找货
