U022-010-R
U022-010-R
    TRIPPLITE
    U022-010-R
U022-010-R 数据手册
USB 2.0 A to B Cable (M/M), 10 ft. (3.05 m) Highlights ● Meets or exceeds USB 2.0 specifications ● Supports faster data transfer rate (1.5 to 480 Mbps) for low speed and high speed devices, including multimedia applications. ● Premium double-shielded cables with tinned copper braid and aluminum mylar foil feature twisted 28AWG data lines, and 24AWG power lines. ● Gold-plated connectors provide superior conductivity ● Comes in retail packaging MODEL NUMBER: U022-010-R System Requirements ● Make the connection between a USB device and your computer's USB port. This USB 2.0 A/B Gold Device Cable assures that you get maximum performance from USB 2.0 devices (e.g. printers, external hard drives). It supports fast data transfer rates of up to 480 Mbps, and is backward compatible with USB 1.1. Package Includes ● Features ● Meets or exceeds USB 2.0 specifications ● Supports faster data transfer rate (1.5 to 480 Mbps) for low speed and high speed devices including multimedia applications ● Premium double-shielded cables with tinned copper braid and aluminum Mylar foil ● Gold-plated connectors and gold-plated copper contacts for superior conductivity ● Molded connectors and integral strain relief for extra durability and long life Specifications OVERVIEW UPC Code 037332116529 Technology USB; USB 2.0 (High Speed) USB Cable Type Passive INPUT Maximum Input Amps 2 CHARGING Total Charging Watts 10 PHYSICAL 1/3 Any device requiring a USB cable (USB 2.0 performance only when used with USB 2.0 device and USB controller). 10-ft. USB 2.0 Gold Cable USBA to USB-B Material of Construction PVC Cable Jacket Color Black Cable Jacket Material PVC Cable Jacket Rating VW-1 Cable Outer Diameter (OD) 5.0mm Cable Length (ft.) 10 Cable Length (m) 3.05 Shipping Dimensions (hwd / in.) 6.10 x 5.40 x 1.60 Shipping Dimensions (hwd / cm) 15.49 x 13.72 x 4.06 Shipping Weight (lbs.) 0.44 Shipping Weight (kg) 0.20 Unit Packaging Type Clamshell ENVIRONMENTAL Operating Temperature Range 32 to 104 F (0 to 40 C) Storage Temperature Range 14 to 131 F (-10 to 55 C) Relative Humidity 5% to 90% RH, Non-Condensing Operating Humidity Range 0% to 90% RH, Non-Condensing Storage Humidity Range 0% to 90% RH, Non-Condensing Power Provided to Connected Device(s) 10W (5V/2A) CONNECTIONS Side A - Connector 1 USB A (MALE) Side B - Connector 1 USB B (MALE) Connector Plating Gold Contact Plating Gold FEATURES & SPECIFICATIONS Data Transfer Rate 480 Mbps USB Specification USB 2.0 (up to 480 Mbps) STANDARDS & COMPLIANCE Product Compliance RoHS; CE (Europe); REACH; FCC (USA) WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty 2/3 © 2022 Tripp Lite. All rights reserved. All product and company names are trademarks or registered trademarks of their respective holders. Use of them does not imply any affiliation with or endorsement by them. Tripp Lite has a policy of continuous improvement. Specifications are subject to change without notice. Tripp Lite uses primary and third-party agencies to test its products for compliance with standards. See a list of Tripp Lite's testing agencies: https://www.tripplite.com/products/product-certification-agencies 3/3
U022-010-R 价格&库存
很抱歉,暂时无法提供与“U022-010-R”相匹配的价格&库存,您可以联系我们找货
