UR024-010-WH
UR024-010-WH
    TRIPPLITE
    UR024-010-WH
UR024-010-WH 数据手册
Universal Reversible USB 2.0 Extension Cable (Reversible A to A M/F), White, 10 ft. (3.05 m) MODEL NUMBER: UR024-010-WH Highlights ● Universal / Reversible A-Male plugs in any direction ● Extend distances of USB 2.0 cables with this extension cable ● Supports faster data transfer rates (1.5 to 480 Mbps) for low speed and high speed devices, especially multimedia applications ● Premium double-shielded cables with tinned copper braid and aluminum mylar foil feature twisted 28/24 AWG data lines ● Gold plated contacts provide superior conductivity System Requirements ● Any USB device requiring a USB cable ● USB2.0 performance only when used with USB2.0 device and USB2.0 controller Reversible USB "A" connector plugs in any direction Package Includes Description This 10-ft. (3.05 m) USB extension cable features a Universal / Reversible, A-Male connector, and is manufactured using USB2.0 cable. Universal / Reversible connector allows the cable to be plugged in any direction. This cable is backwards compatible and can also be used with the older USB 1.1 cables. Made with superior foil shielding for reliable error-free data communications. Features nickel plated connectors and gold plated copper contacts for superior conductivity. The cable is manufactured with molded connectors and integral strain relief for extra durability and long life. The significantly faster data transfer rates of USB 2.0 (up to 480 Mbps) makes it perfect for multimedia applications. Features ● 10-ft. (3.05 m), White, USB 2.0 A-Male to A-Female Extension, with Universal / Reversible "A" Male connector ● USB 2.0 compliant, to 480Mbps transfer rates ● Backward compatible with previous USB generations ● Gold plated contacts and molded ends provide a lifetime of use ● 28AWG Data Pair, 24AWG Power pair Specifications OVERVIEW UPC Code 037332182081 Technology USB 2.0 (High Speed) USB Cable Type Passive PHYSICAL Cable Jacket Color White 1/2 ● Universal Reversible USB 2.0 AMale to A-Female Extension Cable - White - 10-ft. (3.05 m) Cable Length (ft.) 10 Cable Length (m) 3.05 Shipping Dimensions (hwd / in.) 0.25 x 5.40 x 5.70 Shipping Dimensions (hwd / cm) 0.64 x 13.72 x 14.48 Shipping Weight (lbs.) 0.30 Shipping Weight (kg) 0.14 ENVIRONMENTAL Operating Temperature Range 14 to 122 F (-10 to 50 C) Storage Temperature Range 5 to 140 F (-15 to 60 C) Operating Humidity Range 0% to 90% RH, Non-Condensing Storage Humidity Range 0% to 90% RH, Non-Condensing CONNECTIONS Side A - Connector 1 REVERSIBLE USB A (MALE) Side B - Connector 1 USB A (FEMALE) WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2022 Tripp Lite. All rights reserved. All product and company names are trademarks or registered trademarks of their respective holders. Use of them does not imply any affiliation with or endorsement by them. Tripp Lite has a policy of continuous improvement. Specifications are subject to change without notice. Tripp Lite uses primary and third-party agencies to test its products for compliance with standards. See a list of Tripp Lite's testing agencies: https://www.tripplite.com/products/product-certification-agencies 2/2
UR024-010-WH 价格&库存
很抱歉,暂时无法提供与“UR024-010-WH”相匹配的价格&库存,您可以联系我们找货
