U426-003-G2
U426-003-G2
    TRIPPLITE
    U426-003-G2
U426-003-G2 数据手册
USB-C to USB Micro-B Cable (M/M) - USB 3.2, Gen 2 (10 Gbps), Thunderbolt 3 Compatible, 3 ft. (0.91 m) MODEL NUMBER: U426-003-G2 Highlights ● USB 3.1 Gen 2 data transfer speeds up to 10 Gbps ● Power output up to 3A for fastcharging devices ● Reversible USB-C male connector for fast connection the first time ● Error-free signal quality and EMI/RFI protection ● Backward compatible with previous USB generations System Requirements ● Device with a USB-C port ● Device with a USB 3.0 Micro-B port Package Includes ● Connects a computer, laptop, tablet or other device with a USB-C port to a device or peripheral with a USB 3.0 Micro-B port, such as a smartphone or external hard drive. Features Supports USB 3.1 Gen 2 ● Recommended for smartphones, tablets, laptops, computers, external hard drives and other compatible devices ● Data transfer speeds up to 10 Gbps ● Power output up to 3A—perfect for fast charging of most mobile devices ● Same USB Micro-B male connector as USB 3.0 devices ● Backward compatible with previous USB generations USB-C Male Connector ● Fumble-free reversible plug ensures fast, easy connection every time Premium Construction for Superior Signal Transfer ● Foil and braid shielding for error-free signal quality and EMI/RFI protection ● Molded nickel-plated connectors and gold-plated contacts ● Integral strain relief for long life ● Rugged PVC jacket Specifications OVERVIEW UPC Code 037332197382 1/3 U426-003-G2 USB 3.1 Gen 2 (10 Gbps) Cable, USB-C to USB 3.0 Micro-B (M/M), 3 ft. USB Cable Type Passive PHYSICAL Material of Construction PVC Cable Jacket Color Black Cable Jacket Rating VW-1 Cable Outer Diameter (OD) 4.5MM Cable Length (ft.) 3 Cable Length (m) 0.91 Cable Length (in.) 36 Shipping Dimensions (hwd / in.) 9.00 x 6.80 x 0.50 Shipping Dimensions (hwd / cm) 22.86 x 17.27 x 1.27 Shipping Weight (lbs.) 0.20 Shipping Weight (kg) 0.09 ENVIRONMENTAL Operating Temperature Range 14 to 140 F (-10 to 60 C) Storage Temperature Range -4 to 185 F (-20 to 85 C) Relative Humidity 10 to 85% RH, Non-Condensing CONNECTIONS Side A - Connector 1 USB C (MALE) Side B - Connector 1 USB 3.0 MICRO-B (MALE) Connector Plating Nickel Contact Plating Gold FEATURES & SPECIFICATIONS USB Specification USB 3.1 Gen 2 (up to 10 Gbps) STANDARDS & COMPLIANCE Product Compliance RoHS; CE (Europe); REACH; FCC (USA) WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2022 Tripp Lite. All rights reserved. All product and company names are trademarks or registered trademarks of their respective holders. Use of them does not imply any affiliation with or endorsement by them. Tripp Lite has a policy of continuous improvement. Specifications are subject to change without notice. Tripp Lite uses primary and third-party agencies to test its products for compliance with standards. See a list of Tripp Lite's testing agencies: 2/3 https://www.tripplite.com/products/product-certification-agencies 3/3
U426-003-G2 价格&库存
很抱歉,暂时无法提供与“U426-003-G2”相匹配的价格&库存,您可以联系我们找货
