USB-C Cable (M/M) - USB 3.2 Gen 2 (10 Gbps),
Thunderbolt 3 Compatible, 3 ft. (0.91 m)
MODEL NUMBER: U420-003-G2
Highlights
USB 3.1 Gen 2 data transfer
speeds up to 10 Gbps
Error-free signal quality and
EMI/RFI protection
Compatible with both USB-C
and Thunderbolt 3 ports
Reversible USB-C male
connectors on both ends
Power output up to 3A for fastcharging devices
Package Includes
Connects and charges USB-C and Thunderbolt 3 devices at USB 3.1 Gen 2 speeds up to 10 Gbps.
Features
Connects and Charges a USB-C or Thunderbolt 3 Device
The three-foot U420-003-G2 connects two devices with USB-C or Thunderbolt 3 ports or connects one
device to a USB-C wall charger. This cable supports USB 3.1 Gen 2 data transfer rates up to 10 Gbps
and is backward compatible with previous USB generations. Its 3A power output is ideal for fast charging
of mobile devices.
Premium Construction Results in Premium Signal Quality
Molded nickel-plated connectors with gold-plated contacts provide maximum conductivity and minimum
data loss to guarantee a clear transmission free of interference. Foil and braid shielding delivers reliable,
error-free signal quality and protection from EMI/RFI line noise that can distort or destroy data. Integral
strain relief gives the cable extra flexibility, reduces stress, and helps the cable move freely without
cracking or breaking loose from the connector.
Reversible USB-C Connectors Attach in Either Direction
Unlike traditional USB cables that connect in only one direction, the reversible USB-C male connectors
plug into USB-C or Thunderbolt 3 ports in either direction for an instant connection every time.
Specifications
OVERVIEW
UPC Code
037332197368
USB Cable Type
Passive
PHYSICAL
Material of Construction
PVC
Cable Jacket Color
Black
1/2
U420-003-G2 USB 3.1 Gen 2
Cable, USB-C (M/M), 3 ft.
Cable Jacket Rating
VW-1
Cable Outer Diameter (OD)
5.2MM
Cable Length (ft.)
3
Cable Length (m)
0.91
Cable Length (in.)
36
Shipping Dimensions (hwd / in.)
9.00 x 6.50 x 0.50
Shipping Dimensions (hwd / cm)
22.86 x 16.51 x 1.27
Shipping Weight (lbs.)
0.10
Shipping Weight (kg)
0.05
ENVIRONMENTAL
Operating Temperature Range
14 to 140 F (-10 to 60 C)
Storage Temperature Range
-4 to 185 F (-20 to 85 C)
Relative Humidity
10% to 85% RH, Non-Condensing
CONNECTIONS
Side A - Connector 1
USB C (MALE)
Side B - Connector 1
USB C (MALE)
Connector Plating
Nickel
Contact Plating
Gold
FEATURES & SPECIFICATIONS
USB Specification
USB 3.1 Gen 2 (up to 10 Gbps)
STANDARDS & COMPLIANCE
Product Compliance
RoHS; CE (Europe); REACH; FCC (USA)
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
3-year limited warranty
© 2022 Tripp Lite. All rights reserved. All product and company names are trademarks or registered trademarks of their respective holders. Use of them does
not imply any affiliation with or endorsement by them. Tripp Lite has a policy of continuous improvement. Specifications are subject to change without notice.
Tripp Lite uses primary and third-party agencies to test its products for compliance with standards. See a list of Tripp Lite's testing agencies:
https://www.tripplite.com/products/product-certification-agencies
2/2
很抱歉,暂时无法提供与“U420-003-G2”相匹配的价格&库存,您可以联系我们找货
