RCU-G-01.00-BMS-AM
RCU-G-01.00-BMS-AM
    SAMTEC(申泰)
    RCU-G-01.00-BMS-AM
RCU-G-01.00-BMS-AM 数据手册
DESIGNED & DIMENSIONED IN MILLIMETERS[INCHES] REVISION J RCU-X-XX.XX-XXX-XXX PLATING SPECIFICATION -G: .000030 GOLD ON CONTACT AREAS, NICKEL ON SHELLS CABLE LENGTH -XX.XX: "A" (0.25M [9.842] MIN - 50.00M [1968.504] MAX) END 1 OPTION -AMS: SEALED USB A (USB A END SEALED ONLY) -BMS: SEALED USB B (USB B END SEALED ONLY) C 3 "B" = "A" + 35.6[1.40] (SEE NOTE 16) CABLE LENGTH "A" 2 DO NOT SCALE FROM THIS PRINT 1 SEE NOTE 2 6 5 END 1 04 END 2 OPTION -AMS: USB A SEALED (USB A SEALED ONLY) (SEE FIG 1) -AM: USB A NOT SEALED (USB A END NOT SEALED ONLY) (SEE SHEET 2, FIG 2) -BC: BLUNT CUT (SEE SHEET 2, FIG 3) -BM: USB B NOT SEALED (USB B END NOT SEALED) (SEE SHEET 3, FIG 4) -BMS: USB B SEALED (USB B SEALED ONLY) ( SHEET 3, FIG 5) END 2 LABEL-ET 01 04 01 NOTES: 1. C REPRESENTS A CRITICAL DIMENSION. 20.00±10.0 .787±.394 2. SAMTEC LOGO TO APPEAR ON SURFACE AS SHOWN, APPROXIMATELY 6.00[.236] X 3.75[.148]. 3. MOLDED SURFACES SHALL BE CONSISTENT AND SMOOTH. SURFACES TO BE FREE OF SCRATCHES, NICKS, SINK AREAS, VOIDS, OR OTHER BLEMISHES. 4. ALL MULTIPLE CAVITY MOLDS SHALL IDENTIFY EACH CAVITY WITH A NUMBER DESIGNATION LOCATED WHERE SHOWN. 5. ALL IDENTIFICATION MARKS SHALL NOT STAND GREATER THAN 0.05[.002] OFF THE SURFACE OF THE PART. RCU-X-XX.XX-AMS-AMS SHOWN 6. MOLD TO BE INSERTED TO ACCEPT DIFFERENT CABLE DIAMETERS. 7. SURFACE TO BE RECESSED 0.22[.009]. 8. USB LOGO TO BE RAISED 0.25[.010]. 9. USB LOGO'S TO BE ALIGNED TO USB CONNECTORS AS SHOWN. 10. LENGTHS GREATER THAN 05.00M[196.850] ARE NOT SUPPORTED BY USB 2.0 TEST DATA. 11. ASSEMBLY TO BE 100% ELECTRICALLY TESTED FOR OPENS AND SHORTS, HI-POT TESTED AT 200V BEFORE PREMOLD AND AFTER FINAL ASSEMBLY. AFTER FINAL ELECTRICAL TEST, LABEL EACH ASSEMBLY WITH 1 LABEL-ET. 12. ALL EJECTION PIN AND GATE LOCATIONS MUST BE APPROVED BY SAMTEC PRODUCT ENGINEERING. F:\DWG\MISC\MKTG\RCU-X-XX.XX-XXX-XXX-MKT.SLDDRW 13. ANY ADDITIONAL VOIDING AND/OR MODIFICATIONS TO VOIDING MUST BE APPROVED BY UNLESS OTHERWISE SPECIFIED, PROPRIETARY NOTE SAMTEC PRODUCT ENGINEERING. 14. ALL DRAFT MUST BE WITHIN THE SPECIFIED TOLERANCES. DIMENSIONS ARE IN MILLIMETERS. THIS DOCUMENT CONTAINS INFORMATION CONFIDENTIAL AND PROPRIETARY TO 15. ALL INSIDE/OUTSIDE RADII 0.13[.005] MAX UNLESS OTHERWISE STATED. TOLERANCES ARE: SAMTEC, INC. AND SHALL NOT BE REPRODUCED 16. TOLERANCE SHALL BE ± 2% FOR ALL LENGTHS. DECIMALS ANGLES OR TRANSFERRED TO OTHER DOCUMENTS OR 17. MINIMUM LATCH PUSH OUT FORCE: 2.2N[.50LB]. DISCLOSED TO OTHERS OR USED FOR ANY X.X: 0.3 [.01] 2 520 PARK EAST BLVD, NEW ALBANY, IN 47150 18. THIS IS A COMPONENT OF USBP-A-01-G-B-01 (CALLED OUT ON THE BOM), BUT LABELED INDIVIDUALLY FOR PURPOSE OTHER THAN THAT WHICH IT WAS X.XX: 0.13 [.005] PHONE: 812-944-6733 FAX: 812-948-5047 ASSEMBLY PURPOSES. OBTAINED WITHOUT THE EXPRESSED WRITTEN X.XXX: 0.051 [.0020] CONSENT OF SAMTEC, INC. e-Mail info@SAMTEC.com code 55322 19. THIS IS A COMPONENT OF USBP-B-01-G-B-01 (CALLED OUT ON THE BOM), BUT LABELED INDIVIDUALLY FOR SHEET SCALE: 1:1 DESCRIPTION: ASSEMBLY PURPOSES. MATERIAL: DO NOT SCALE DRAWING 20. ASSEMBLY TO BE SHIPPED IN BULK PACKAGED WITH ASBBLT4X5.5 ON EACH END PER PACKAGING STANDARD CO-RF-WI-3001-M. CABLE: PVC, COPPER, PET RECTANGULAR CABLE USB 21. NOTE DELETED. CONNECTOR: GLASS FILLED THERMOPLASTIC, COPPER ALLOY 22. ANY CHANGE MADE TO -AM & -BM OVERMOLD MUST BE MADE TO SCPU-17-XX.XX-XXX-XXX. DWG. NO. LATCH: BeCu 23. THIS IS A COMPONENT OF USBP-B-02-G-B-01 (CALLED OUT ON THE BOM), BUT LABELED INDIVIDUALLY FOR PREMOLD: PTC ASSEMBLY PURPOSES. OVERMOLD: PAGG, MAX REGRIND: 10% 24. MEASURE OVERMOLD IN BOTH CORNERS AND IN THE MIDDLE OF THE PART. NON-SEALED OVERMOLD: PVC, MAX REGRIND: 30% 25. USE TABLE 3, SHT 5 AND THE FIGURES BELOW FOR PIN NUMBERING AND WIRE COLOR; IGNORE ANY NUMBERING ON THE BODIES. BY: T NEWTON 02/17/2010 SHEET 1 FIG 1 RCU-X-XX.XX-XXX-XXX OF 10 REVISION J 7 04 01 04 FIG 2 01 RCU-X-XX.XX-AMS-AM SHOWN (SAME AS FIG 1, EXCEPT AS SHOWN) "B" = "A" + 17.8[.70] (SEE NOTE 16) 04 C 01 FIG 3 RCU-X-XX.XX-AMS-BC SHOWN (SAME AS FIG 1, EXCEPT AS SHOWN) PROPRIETARY NOTE THIS DOCUMENT CONTAINS INFORMATION CONFIDENTIAL AND PROPRIETARY TO SAMTEC, INC. AND SHALL NOT BE REPRODUCED OR TRANSFERRED TO OTHER DOCUMENTS OR DISCLOSED TO OTHERS OR USED FOR ANY PURPOSE OTHER THAN THAT WHICH IT WAS OBTAINED WITHOUT THE EXPRESSED WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING SHEET SCALE: 1:1 F:\DWG\MISC\MKTG\RCU-X-XX.XX-XXX-XXX-MKT.SLDDRW 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 DESCRIPTION: RECTANGULAR CABLE USB DWG. NO. RCU-X-XX.XX-XXX-XXX BY: T NEWTON 02/17/2010 SHEET 2 OF 10 REVISION J 8 04 01 01 02 04 03 FIG 4 RCU-X-XX.XX-AMS-BM SHOWN (SAME AS FIG 1, EXCEPT AS SHOWN) 8 04 01 FIG 5 RCU-X-XX.XX-AMS-BMS SHOWN (SAME AS FIG 1, EXCEPT AS SHOWN) 02 04 03 PROPRIETARY NOTE THIS DOCUMENT CONTAINS INFORMATION CONFIDENTIAL AND PROPRIETARY TO SAMTEC, INC. AND SHALL NOT BE REPRODUCED OR TRANSFERRED TO OTHER DOCUMENTS OR DISCLOSED TO OTHERS OR USED FOR ANY PURPOSE OTHER THAN THAT WHICH IT WAS OBTAINED WITHOUT THE EXPRESSED WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING SHEET SCALE: 1:1 F:\DWG\MISC\MKTG\RCU-X-XX.XX-XXX-XXX-MKT.SLDDRW 01 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 DESCRIPTION: RECTANGULAR CABLE USB DWG. NO. RCU-X-XX.XX-XXX-XXX BY: T NEWTON 02/17/2010 SHEET 3 OF 10 REVISION J C "A" (SEE NOTE 16) (SEE TABLE 2) C UCA-03-01 12.00±1.00 .472±.039 IN-PROCESS 1 CUT CABLE TO LENGTH AND STRIP OUTER JACKET TWISTED SHIELD C 3.18±0.20 .125±.008 IN-PROCESS 2 FOLD SHIELD BACK, REMOVE FOIL & TWIST SHIELD IN-PROCESS 3 STRIP INDIVIDUAL WIRES AND DIP IN TIN "B" = "A" + 35.6[1.40] (SEE NOTE 16) 04 C 01 04 01 01 END 2 END 1 END 1 END 2 04 -AMS-XXX: IN-PROCESS 5 TERMINATE SECOND END TO SUB-USB-A-G-B-01 (SEE NOTE 18 & 25) -AMS-XXX: IN-PROCESS 4 TERMINATE TO SUB-USB-A-G-B-01 (SEE NOTE 18 & 25) PROPRIETARY NOTE THIS DOCUMENT CONTAINS INFORMATION CONFIDENTIAL AND PROPRIETARY TO SAMTEC, INC. AND SHALL NOT BE REPRODUCED OR TRANSFERRED TO OTHER DOCUMENTS OR DISCLOSED TO OTHERS OR USED FOR ANY PURPOSE OTHER THAN THAT WHICH IT WAS OBTAINED WITHOUT THE EXPRESSED WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING SHEET SCALE: 1:1 F:\DWG\MISC\MKTG\RCU-X-XX.XX-XXX-XXX-MKT.SLDDRW 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 DESCRIPTION: RECTANGULAR CABLE USB DWG. NO. RCU-X-XX.XX-XXX-XXX BY: T NEWTON 02/17/2010 SHEET 4 OF 10 REVISION J USBS-A-N-01-01 END 1 USBS-A-N-02-01 END 2 END 2 END 1 -AMS-XXX: IN-PROCESS 7 -AMS-XXX: IN-PROCESS 6 ADD USBS-A-N-02-01 SHELL (SEE NOTE 18) ADD USBS-A-N-01-01 SHELL (SEE NOTE 18) C 14.70 .579 (TYP) END 1 END 2 18.90 .744 (T.S.C.) R1.50 .059 (TYP) 4 CL 37.95 1.494 (TYP) -AMS-XXX: IN-PROCESS 8 11.80 .465 (T.S.C.) CRIMP SHELLS OVER BRAID AND TRIM EXCESS SHIELD 9.60 .378 -AMS-AMS: IN-PROCESS 9 PREMOLD F:\DWG\MISC\MKTG\RCU-X-XX.XX-XXX-XXX-MKT.SLDDRW PROPRIETARY NOTE THIS DOCUMENT CONTAINS INFORMATION CONFIDENTIAL AND PROPRIETARY TO SAMTEC, INC. AND SHALL NOT BE REPRODUCED OR TRANSFERRED TO OTHER DOCUMENTS OR DISCLOSED TO OTHERS OR USED FOR ANY PURPOSE OTHER THAN THAT WHICH IT WAS OBTAINED WITHOUT THE EXPRESSED WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING SHEET SCALE: 1:1 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 DESCRIPTION: RECTANGULAR CABLE USB DWG. NO. RCU-X-XX.XX-XXX-XXX BY: T NEWTON 02/17/2010 SHEET 5 OF 10 REVISION J 48.45 1.907 14.50 .571 13.77 .542 18.95 .746 C 10.94 .431 15.90 .626 18.95 .746 "A" 'C' 2.5 .10 (TYP) 7.00 .276 CL 9.1 .36 R1.0 .04 SEE NOTE 8 SEE NOTE 7 DETAIL 'E' SCALE 2 : 1 R0.8 .03 (TYP) C 26.089+-0.711 0.100 1.027+-.028 .004 "A" 'E' 4.80±0.05 .189±.002 C 15.5 .61 'B' 33.33 1.312 R0.64 .025 (TYP) 12.3 .48 8.75 .345 14.45 .569 5.5 .22 (TYP) 83° 5.3 .21 C 8.26 .325 REF R4.13 .162 (4 PLCS) 11.950 .4705 (SEE NOTE 24) CL R0.50 .020 (12 PLCS) R1.0 .04 14.10 .555 REF -AMS-AMS: IN-PROCESS 10 'D' 5.00 .197 OVERMOLD (SOME COMPONENTS REMOVED FOR CLARITY) R0.64 .025 (TYP) 1.25 .049 (TYP) 8.40 .331 0.76 .030 2.79 .110 1.55 .061 27.15 1.069 S C 19.500 .7677 (SEE NOTE 24) 22.00 .866 95° 3.56 .140 DETAIL 'B' SCALE 2 : 1 R1.27 .050 30° (TYP) DETAIL 'D' SCALE 2 : 1 F:\DWG\MISC\MKTG\RCU-X-XX.XX-XXX-XXX-MKT.SLDDRW PROPRIETARY NOTE 6.00 .236 SECTION "A"-"A" SCALE 2 : 1 (SOME COMPONENTS REMOVED FOR CLARITY) 85° REF R0.25 .010 (2 PLCS) DETAIL 'C' SCALE 2 : 1 THIS DOCUMENT CONTAINS INFORMATION CONFIDENTIAL AND PROPRIETARY TO SAMTEC, INC. AND SHALL NOT BE REPRODUCED OR TRANSFERRED TO OTHER DOCUMENTS OR DISCLOSED TO OTHERS OR USED FOR ANY PURPOSE OTHER THAN THAT WHICH IT WAS OBTAINED WITHOUT THE EXPRESSED WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING SHEET SCALE: 1:1 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 DESCRIPTION: RECTANGULAR CABLE USB DWG. NO. RCU-X-XX.XX-XXX-XXX BY: T NEWTON 02/17/2010 SHEET 6 OF 10 REVISION J C "B" = "A" + 17.8[.70] (SEE NOTE 16) END 1 -AMS-BC: IN-PROCESS 11 -AMS-AM: IN-PROCESS 9 END 2 PREMOLD (SAME AS -AMS-AMS: IN-PROCESS 9 ,EXCEPT AS SHOWN) CUT CABLE IN HALF AND TRIM TO LENGTH 40.4 1.59 32.25 1.270 26.00 1.024 21.50 .846 19.00 .748 C 14.75 .581 12.00 .472 11.14 .439 7.50 .295 4.00 .157 6.00 .236 10.00 .394 15.90 .626 'F' R8.00 .315 1.40 .055 1.40 .055 (3 PLCS) 6.50 .256 0.90 .035 (3 PLCS) 0.70 .028 (TYP) 0.40 .016 (TYP) DETAIL 'F' SCALE 1.5 : 1 7.80 .307 (SEE NOTE 22) PROPRIETARY NOTE -AMS-AM: IN-PROCESS 10 OVERMOLD (SAME AS -AMS-AMS: IN-PROCESS 10, EXCEPT AS SHOWN) THIS DOCUMENT CONTAINS INFORMATION CONFIDENTIAL AND PROPRIETARY TO SAMTEC, INC. AND SHALL NOT BE REPRODUCED OR TRANSFERRED TO OTHER DOCUMENTS OR DISCLOSED TO OTHERS OR USED FOR ANY PURPOSE OTHER THAN THAT WHICH IT WAS OBTAINED WITHOUT THE EXPRESSED WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING SHEET SCALE: 1:1 F:\DWG\MISC\MKTG\RCU-X-XX.XX-XXX-XXX-MKT.SLDDRW 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 DESCRIPTION: RECTANGULAR CABLE USB DWG. NO. RCU-X-XX.XX-XXX-XXX BY: T NEWTON 02/17/2010 SHEET 7 OF 10 REVISION J "B" = "A" + 35.6[1.40] (SEE NOTE 16) 04 01 C SUB-USB-B-G-B-01 END 1 02 03 01 04 END 1 USBS-B-N-01-01 (SEE NOTE 19) END 2 END 2 -AMS-BM: IN-PROCESS 6 -AMS-BM: IN-PROCESS 5 ADD USBS-A-N-01-01 & USBS-B-N-01-01 SHELLS (SAME AS -AMS-XXX: IN-PROCESS 6, EXCEPT AS SHOWN (SEE NOTE 18 & NOTE 19) TERMINATE SECOND END TO SUB-USB-B-G-B-01 (SAME AS -AMS-XXX: IN-PROCESS 5, EXCEPT AS SHOWN) (SEE NOTE 18, 19 & 25) USBS-A-N-02-01 (SEE NOTE 18) USBS-A-N-01-01 (SEE NOTE 18) USBS-B-N-02-01 (SEE NOTE 19) END 1 END 1 END 2 END 2 -AMS-BM: IN-PROCESS 8 -AMS-BM: IN-PROCESS 7 CRIMP SHELLS OVER BRAID AND TRIM EXCESS SHIELD (SAME AS -AMS-XXX: IN-PROCESS 8, EXCEPT AS SHOWN) ADD USBS-A-N-02-01 & USBS-B-N-02-01 SHELLS (SAME AS -AMS-XXX: IN-PROCESS 7, EXCEPT AS SHOWN) (SEE NOTE 18 & NOTE 19) 41.40 1.630 33.25 1.309 END 1 28.15 1.108 20.50 .807 END 2 17.50 .689 2.70 .106 6.00 .236 2.20 .087 -AMS-BM: IN-PROCESS 9 PREMOLD (SAME AS -AMS-AMS: IN-PROCESS 9, EXCEPT AS SHOWN) 1.40 .055 7.50 .295 10.70 .421 9.00 .354 C 11.85 .467 0.90 .035 (3 PLCS) R5.00 .197 7.50 .295 6.50 .256 11.20 .441 'G' 0.40 .016 (TYP) 0.70 .028 (TYP) 1.00 .039 (2 PLCS) DETAIL 'G' SCALE 2 : 1 (SEE NOTE 22) 23.03 .907 PROPRIETARY NOTE 8° -AMS-BM: IN-PROCESS 11 THIS DOCUMENT CONTAINS INFORMATION CONFIDENTIAL AND PROPRIETARY TO SAMTEC, INC. AND SHALL NOT BE REPRODUCED OR TRANSFERRED TO OTHER DOCUMENTS OR DISCLOSED TO OTHERS OR USED FOR ANY PURPOSE OTHER THAN THAT WHICH IT WAS OBTAINED WITHOUT THE EXPRESSED WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING SHEET SCALE: 1:1 OVERMOLD (SAME AS -AMS-AMS: IN-PROCESS 10, EXCEPT AS SHOWN) F:\DWG\MISC\MKTG\RCU-X-XX.XX-XXX-XXX-MKT.SLDDRW 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 DESCRIPTION: RECTANGULAR CABLE USB DWG. NO. RCU-X-XX.XX-XXX-XXX BY: T NEWTON 02/17/2010 SHEET 8 OF 10 REVISION J 04 01 03 02 C END 1 END 2 SUB-USB-B-G-B-01 04 01 03 02 END 1 -BMS-XXX: IN-PROCESS 4 SUB-USB-B-G-B-01 END 2 02 03 01 04 -BMS-BC: IN-PROCESS 5 TERMINATE TO SUB-USB-B-G-B-01 (SAME -AMS-XXX: IN-PROCESS 4, EXCEPT AS SHOWN) (SEE NOTE 23 & 25) USBS-B-N-03-01 "B" = "A" + 35.6[1.40] (SEE NOTE 16) TERMINATE TO SUB-USB-B-G-B-01 (SAME AS -AMS-AMS: IN-PROCESS 5, EXCEPT AS SHOWN) (SEE NOTE 23 & 25) USBS-B-N-03-01 USBS-B-N-02-01 USBS-B-N-02-01 -BMS-BC: IN-PROCESS 7 -BMS-BC: IN-PROCESS 6 ADD USBS-B-N-02-02 (SAME AS -AMS-AMS: IN-PROCESS 7, EXCEPT AS SHOWN) (SEE NOTE 23) ADD USBS-B-N-03-01 (SAME AS -AMS-AMS: IN-PROCESS 6, EXCEPT AS SHOWN) (SEE NOTE 23) -BMS-BC: IN-PROCESS 8 CRIMP SHELLS OVER BRAID AND TRIM SHIELD (SAME AS -AMS-AMS: IN-PROCESS 8, EXCEPT AS SHOWN) C 14.80 .583 (TYP) 17.80 .701 (T.S.C.) CL 38.05 1.498 (TYP) 15.25 .600 (T.S.C.) CL 9.60 .378 -BMS-BC: IN-PROCESS 9 PREMOLD (SAME AS -AMS-AMS: IN-PROCESS 9, EXCEPT AS SHOWN) PROPRIETARY NOTE THIS DOCUMENT CONTAINS INFORMATION CONFIDENTIAL AND PROPRIETARY TO SAMTEC, INC. AND SHALL NOT BE REPRODUCED OR TRANSFERRED TO OTHER DOCUMENTS OR DISCLOSED TO OTHERS OR USED FOR ANY PURPOSE OTHER THAN THAT WHICH IT WAS OBTAINED WITHOUT THE EXPRESSED WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING SHEET SCALE: 1:1 F:\DWG\MISC\MKTG\RCU-X-XX.XX-XXX-XXX-MKT.SLDDRW 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 DESCRIPTION: RECTANGULAR CABLE USB DWG. NO. RCU-X-XX.XX-XXX-XXX BY: T NEWTON 02/17/2010 SHEET9 OF 10 REVISION J 48.55 1.911 15.98 .629 19.05 .750 C 10.99 19.03 .749 .433 C +0.711 +.0280 16.550 .6516 (SEE NOTE 24) 19.05 .750 CL 23.139 - 0.100 .9110 - .0039 15.6 .62 8.8 .35 4.90±0.05 .193±.002 13.87 .546 C CL CL 18.10 .713 "H" 15.600 .6142 (SEE NOTE 24) CL R2.75 .108 (4 PLCS) C C "H" -BMS-BC: IN-PROCESS 10 24.25 .955 OVERMOLD (SAME AS -AMS-AMS: IN-PROCESS 10, EXCEPT AS SHOWN) SECTION "H"-"H" PROPRIETARY NOTE THIS DOCUMENT CONTAINS INFORMATION CONFIDENTIAL AND PROPRIETARY TO SAMTEC, INC. AND SHALL NOT BE REPRODUCED OR TRANSFERRED TO OTHER DOCUMENTS OR DISCLOSED TO OTHERS OR USED FOR ANY PURPOSE OTHER THAN THAT WHICH IT WAS OBTAINED WITHOUT THE EXPRESSED WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING SHEET SCALE: 1:1 F:\DWG\MISC\MKTG\RCU-X-XX.XX-XXX-XXX-MKT.SLDDRW 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 DESCRIPTION: RECTANGULAR CABLE USB DWG. NO. RCU-X-XX.XX-XXX-XXX BY: T NEWTON 02/17/2010 SHEET 10OF 10
RCU-G-01.00-BMS-AM 价格&库存
很抱歉,暂时无法提供与“RCU-G-01.00-BMS-AM”相匹配的价格&库存,您可以联系我们找货
