U328-036
U328-036
    TRIPPLITE
    U328-036
U328-036 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States USB 3.0 SuperSpeed Active Repeater Cable (A to B M/M), 36 ft. (10.97 m) MODEL NUMBER: U328-036 Highlights ● 36-ft. (10.97 m) USB3.0 SuperSpeed A-B Active Cable ● Overcomes the 5-meter USB barrier ● Built-in repeater maintains SuperSpeed USB 3.0 signal quality Locate a printer or other USB peripheral 36-ft. from your computer. Description Tripp Lite's SuperSpeed USB 3.0 Active A-B cable overcomes the 5-meter USB distance limitation with an active repeater in the middle of the cable. Now USB printers and other devices can be located up to 36-ft. (10.97 m) away from the computer in a single, non-daisychainable run, with no need for extension cables. Full 5Gbps speed is maintained along the entire length of the cable. Backward compatible to USB 1.1 and 2.0 . Plug-and-play, Windows and MAC compatible. System Requirements ● A USB 3.0 port and USB 3.0 device (with type B jack) are required to meet USB 3.0 speeds. A USB 2.0 or 1.1 port and/or device can be used, but you will not be able to achieve USB 3.0 speeds. ● Not for use with Xbox (see Xbox website for details on extending devices with Xbox) Features ● Connect a computer to a printer or other USB device up to 36-ft. (10.97 m) away ● SuperSpeed USB 3.0, Hi-Speed 2.0 and USB 1.1 compatible ● Active repeater maintains 5Gbps signal integrity ● USB "A" to USB "B" connections ● Windows 98/ME/2000/XP/Vista/WIN7/8/10 and MAC compatible ● Cable length: 36-ft. Weight: 2lb. ● Repeater Pod dimension: 16.75 x 57.3 x 31.7 (mm.) / 0.7 x 2.3 x 1.3 (in.) Package Includes ● Specifications OVERVIEW UPC Code 037332181848 USB Cable Type Active PHYSICAL Cable Jacket Color Black Cable Length (ft.) 36 Cable Length (m) 10.98 Shipping Dimensions (hwd / in.) 9.10 x 10.60 x 0.01 Shipping Dimensions (hwd / cm) 23.11 x 26.92 x 0.03 Shipping Weight (lbs.) 1.20 Shipping Weight (kg) 0.54 CONNECTIONS Side A - Connector 1 USB 3.0 A (MALE) Side B - Connector 1 USB 3.0 B (MALE) 1/2 36-ft. (10.97 m) SuperSpeed USB3.0 A/B Active Device Cable (A Male to B Male) 1000 Eaton Boulevard Cleveland, OH 44122 United States WARRANTY & SUPPORT Product Warranty Period (Worldwide) 3-year limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 2/2
U328-036 价格&库存
很抱歉,暂时无法提供与“U328-036”相匹配的价格&库存,您可以联系我们找货
