U330-10M
U330-10M
    TRIPPLITE
    USBCABLE
U330-10M 数据手册
USB 3.0 SuperSpeed Active Extension Repeater Cable (A M/F), 10M (32.8 ft.) MODEL NUMBER: U330-10M Highlights ● Extend a USB 3.0 signal 32.8-ft. (10 m) ● Increase the extension distance to 65.61-ft. (20 m) by connecting two U330-10M together ● Supports USB 3.0 SuperSpeed data transfer rates up to 5Gbps System Requirements ● A USB 3.0 Computer port and USB 3.0 device are required to meet USB 3.0 speeds. A USB 2.0 port or device can be used, but you will be limited to the speeds of that port / device. ● The U330-10M provides up to 120mA of power to the connected device. If your device requires more than 120mA of power, an external power supply will be required. The U330-10M accepts a 5V, 2A power supply with a 3.5 x 1.35mm DC jack. The output plug on the power supply should have a positive tip and a negative sleeve. Description Tripp Lite's 32.8-ft. (10 m) USB 3.0 active extension cable is a bus powered extension cable that can be used to increase the length of a device cable without the worry of signal loss and potential performance problems. Increase the extension distance to 65.61-ft. (20 m) by connecting two U330-10M together. USB limits a cable's length to 16-ft. (4.88 m). Any length above 16-ft. (4.88 m) requires the use of an active cable such as this one. This cable has a signal booster built in. The cable must be plugged directly into a USB port (either on the PC or a hub). Use a standard 6-ft. (1.83 m), 10-ft. (3.05 m), or 15-ft. (4.57 m) USB 3.0 A-B cable to reach the desired distance. The U330-10M provides up to 120mA of power to the connected device. If your device requires more than 120mA of power, an external power supply will be required. The U330-10M accepts a 5V, 2A power supply with a 3.5 x 1.35mm DC jack. The output plug on the power supply should have a positive tip and a negative sleeve. Features ● Extend a USB 3.0 signal 32.8-ft. (10 m) ● Increase the extension distance to 65.61-ft. (20 m) by connecting two U330-10M together ● Works together with standard USB 3.0 cables ● Provides up to 120mA of power to the connected device. If your device requires more than 120mA of power, an external power supply will be required. ● Accepts a 5V, 2A power supply with a 3.5 x 1.35mm DC jack. The output plug on the power supply should have a positive tip and a negative sleeve. ● Backward compatible to previous USB generations Specifications OVERVIEW UPC Code 037332182722 PHYSICAL 1/2 Package Includes ● 32.8-ft. (10 m) USB3.0 Super Speed A/A Active Extension Cable (USB-A M/F) Color Black Cable Jacket Color Black Cable Length (ft.) 32.8 Cable Length (m) 10.00 Shipping Dimensions (hwd / cm) 26.92 x 22.86 x 0.25 Shipping Dimensions (hwd / in.) 10.60 x 9.00 x 0.10 Shipping Weight (kg) 0.50 Shipping Weight (lbs.) 1.10 CONNECTIONS Side A - Connector 1 USB 3.0 A (MALE) Side B - Connector 1 USB 3.0 A (FEMALE) STANDARDS & COMPLIANCE Product Compliance RoHS WARRANTY Product Warranty Period (Worldwide) 3-year limited warranty © 2022 Tripp Lite. All rights reserved. All product and company names are trademarks or registered trademarks of their respective holders. Use of them does not imply any affiliation with or endorsement by them. Tripp Lite has a policy of continuous improvement. Specifications are subject to change without notice. Tripp Lite uses primary and third-party agencies to test its products for compliance with standards. See a list of Tripp Lite's testing agencies: https://www.tripplite.com/products/product-certification-agencies 2/2
U330-10M 价格&库存
很抱歉,暂时无法提供与“U330-10M”相匹配的价格&库存,您可以联系我们找货
