U030-06N-HUB
U030-06N-HUB
    TRIPPLITE
    USB 2.0 A MINI B EXT CABLE 6"
U030-06N-HUB 数据手册
USB 2.0 Hi-Speed Port Liberator (USB A to 5-Pin Mini B) Adapter Cable with 500mA Charging port, 6-in. MODEL NUMBER: U030-06N-HUB Highlights ● 6 in. USB 2.0 A to Mini-B, with 1-port hub ● 480Mbps speed ● Plug-and-Play System Requirements ● Computer with USB 2.0 port Package Includes ● Easily and conveniently charge your smartphone from your notebook/laptop computer. Description Tripp Lite's 6 in. USB 2.0 port liberator allows connection of a cell/smartphone to your notebook/laptop computer for charging and syncing while creating a second port for other peripheral connections, such as a printer, external mouse, etc. Plug the U030-06N-HUB into your notebook's USB port and your 5-pin, Mini-B phone port into the Mini-B Male pigtail cable. A second female "A" port is now created for attaching other USB peripherals, such as a printer, USB external mouse, etc. ( note: will not charge iPad or other tablets and devices that require 2.5 Amps or higher ). Features ● 6 in. USB A Male to 5-pin Mini-B Male, with female "A" hub port ● Allows charging/syncing of cell / smartphones ● 480mbps data pass-through ● 500mA on charging port Specifications OVERVIEW UPC Code 037332173270 Technology USB 2.0 (High Speed) OUTPUT Output Amp Capacity 0.5 1/2 USB 2.0 Port Liberator Cable - 5 pin mini-B With Built-in Charging Hub - 6in PHYSICAL Color Gray; White Shipping Dimensions (hwd / in.) 0.25 x 3.00 x 4.00 Shipping Dimensions (hwd / cm) 0.64 x 7.62 x 10.16 Shipping Weight (lbs.) 0.04 Shipping Weight (kg) 0.02 CONNECTIONS Number of Ports 1 Side A - Connector 1 USB A (MALE) Side B - Connector 1 USB MINI-B 5-PIN (MALE) Side B - Connector 2 USB A (FEMALE) WARRANTY Product Warranty Period (Worldwide) Lifetime limited warranty © 2022 Tripp Lite. All rights reserved. All product and company names are trademarks or registered trademarks of their respective holders. Use of them does not imply any affiliation with or endorsement by them. Tripp Lite has a policy of continuous improvement. Specifications are subject to change without notice. Tripp Lite uses primary and third-party agencies to test its products for compliance with standards. See a list of Tripp Lite's testing agencies: https://www.tripplite.com/products/product-certification-agencies 2/2
U030-06N-HUB 价格&库存
很抱歉,暂时无法提供与“U030-06N-HUB”相匹配的价格&库存,您可以联系我们找货
