Page 1 of 2
Retired Product
This is a retired product. There is an updated version available: CAB-12016
SparkFun Cerberus USB Cable - 6ft (Sale)
CAB-11515
images are CC BY-NC-SA 3.0
Description: You’ve got the wrong USB cable. It doesn’t matter which one you have,
it’s the wrong one. But what if you could have the right one? What if you could have
the right one every time? Enter: The Cerberus.
The Cerberus is a three-headed cable-beast that will ensure that you’re never stuck
looking for a USB cable that fits your device. At one end of the Cerberus you have the
standard A-type connector, which you can plug into your computer or USB power
supply; At the other end are three common USB connectors: B, mini-B and micro-B.
The Cerberus can transfer both power and data just like any USB cable, but it’s not a
hub so don’t try to connect three data devices at the same time! You may run into
issues when transferring large amounts of data (hard drives, flash drives, etc), so it’s
best to just use it for low-speed applications like microcontrollers or charging devices.
If you’re still trying to wrap your head around the world of USB cables, why not check
out our USB Buying Guide?
Note: This idea originally came from our friend and favorite button maker in the
Oakland area, CTP. If you see him, please give him a high-five for us.
Note: The only compatibility problem that we’ve found with these cables is with
Android device and mass storage devices. You can charge an Android device using
the Cerberus but it won’t identify to the computer unless you’re running Linux. The
cable really wasn’t designed for high speed data transmission, so using it with mass
storage devices can be problematic.
Dimensions: 6' Long
Page 2 of 2
Features:
• Single USB-A Connector at Host End
• USB-B, mini-B and micro-B Connectors at Device End
https://www.sparkfun.com/products/retired/11515
10/8/2015
很抱歉,暂时无法提供与“CAB-11515”相匹配的价格&库存,您可以联系我们找货
