20888610030
20888610030
    HARTING(浩亭)
    SYPCEM CABLE HAN-Q8/0/ MET
20888610030 数据手册
HARTING Electric Han-Power® Energy Bus Components People ï Power ï Partnership Han® Data Sheet 0080-4 Han-Power® T Han-Power® T Part-Number Drawing Dimensions in mm Drawing Dimensions in mm 09 12 008 4701 Cable gland order separately see page 5 Han-Power® T with cable Part-Number 09 12 008 4707 Included in delivery: 3 m pre-assembled cable Description The Han-Power® T connector is applied for the assembly of serial power bus. Due to the T-functionality several users (i.e. motors, etc.) can be connected in series, as long as the total does not exceed the maximum current. The energy supply is realized by means of a terminal block with screw termination. The energy transmission as well as the device interface are realized by means of a Han® Q 8/0 connector. Features • 6 screw terminations for max. 4 mm² wire gauges • Space-saving and compact design • Leading protective ground in Han® Q 8/0 insert • Assembly with standard tools • T-functionality for max. 500 V: - energy bus structure: 7 x 4 mm2 - power supply structure: 7 x 2.5 mm2 • T-piece with pre-assembled cable (valid only for 09 12 008 4707) - 7 x 2.5 mm² wire gauge - maximum cable length 3 m Page 2 / 8 Han-Power® S Han-Power® S Part-Number Drawing Dimensions in mm Part-Number Drawing Dimensions in mm 09 12 000 9970 09 12 000 9971 09 12 000 9972 09 12 000 9973 Cable Æ 10-13 13-16 16-19 19-22 09 12 008 4801 Abzweig mit angeformtem Tüllengehäuse Sealings Description The Han-Power® S connector is suitable for the assembly of serial power bus. Having assembled the energy supply Han-Power® S can be inserted at any place of the power cable. The cable mantle has to be removed, the conductor is placed without interruption in the IDC. Han-Power® S is applied for wire gauges of 2.5 mm² up to 4 mm². For the distribution to the device a Han® Q 8/0 cable to cable housing is used. Features 6 IDCs + PE for 2.5 mm² up to 4 mm2 wire gauge No interruption of the energy supply Space-saving and compact design Leading protective ground in Han® Q 8/0 insert Assembly with standard tools T-functionality for max. 500 V: - energy bus structure: 7 x 4 mm2 - power supply structure: 7 x 2.5 mm2 • Distribution to device can be realized with a Han® Q 8/0 cable to cable housing • • • • • • Page 3 / 8 Han-Power® Technical Details DIN VDE 61 984 DIN VDE 0110 Inserts Han® Q 8/0 Number of contacts Bemessungsstrom Rated voltage Test voltage Pollution degree Insulation resistance Flammability acc. to UL 94 Mechanical working life - mating cycles 6 + PE 25 A 500 V 3 kV 3 > 1010 W V0 Derating-Diagram Han-Power® T acc. to DIN IEC 512-3 Working current [A] Specifications > 500 Contacts Material Surface - hard-silver plated Contact resistance Termination - mm² - AWG Ambient temperature [C°] copper alloy Han® Q 8/0 partly loaded with wire gauge: 7 x 4 mm² 3 µm Ag £ 1 mW 2.5 - 4 mm² 18 - 12 Derating-Diagram Han-Power® S Hoods / housings Material Colour Sealing Temperature range - Power T - Power S Flammability acc. to UL 94 Material of locking lever - Power T Degree of protection acc. to DIN 40050 in locked position Cable gland - Power-T polycarbonate RAL 9005 NBR Working current [A] acc. to DIN IEC 512-3 - 25° C ... + 80° C - 25° C ... + 40° C V0 polyamide IP 65 Pg 16 Ambient temperature [C°] 1 = wire gauge 2.5 mm² 2 = wire gauge 4 mm² Page 4 / 8 Han® Q 8/0 Hoods / Housings Idenification Part-Number Drawing Dimensions in mm Hood with Pg 16 thread 09 12 008 0527 Hood with Pg 16 thread 09 12 008 0427 Cable to cable hood with Pg 16 thread Bulkhead mounted housing 09 12 008 0727 09 12 008 0327 Bulkhead mounted housing angled version Panel cut out 09 12 008 0902 Cover for for male insert female insert 09 12 008 5407 09 12 008 5408 Cable gland order separately 09 00 000 5059 SW 24 Page 5 / 8 cable min. max. 11.5 15.5 Han-Power® Han® Q 8/0 Inserts Part-Number Drawing Dimensions in mm Drawing Dimensions in mm Crimp termination Crimp contacts order separately Han® Contacts Female insert Male insert 09 12 008 3001 09 12 008 3101 Wire Gauge mm2 Part-Number Power contacts Silver plated Relay contact Operating contact Identification 1.5 2.5 4.0 09 33 000 6104 09 33 000 6204 09 33 000 6102 09 33 000 6202 09 33 000 6107 09 33 000 6207 Identification of the Crimp Contacts Identification Wire gauge Stripping length 2 grooves 1.5 mm² AWG 16 7.5 mm 2 grooves 2.5 mm² AWG 14 no grooves Example for installation Han-Power® T Han-Power® S Page 6 / 8 4 mm² AWG 12 7.5 mm 7.5 mm Han-InduNet® Cabling System Cabling System Han® Q 8/0 Energy bus transmission Connector: conforming product More informationen conc. DESINA: www.desina.de Features Components Hoods Han® Q 8/0 hoods cable glands order separately Plastic version Metal version polycarbonate zinc die cast Inserts* Han® Q 8/0 male and female are available with standard crimp contacts Han® E, silver (optional gold) plated * For further information see catalogue ‘Industrial Division Han® Fiber Optic Components and Systems’ or ‘www.HARTING.com’ Cable Outside diameter D Material outside jacket Construction: electrical (power supply) < 14 mm PUR 7 x 2.5 mm2 Technical Details Features Temperature range - little movements - permanent movements -40° C ... +90° C -20° C ... +70° C Degree of protection IP 65 / IP 67 Operating rated voltage [DC] 500 V Operating rated current Contact arrangement male female - Chemical application conditions: very resistant to oil and chemicals 25 A 1 2 3 4 5 6 7 8 PE Optional reserved for N L2 - Reserved for (+24V) Reserved for (0V) L3 - L1 PE Page 7 / 8 Han-InduNet® Cabling System Cabling System in fixed lengths Part-Number Cable lengths in m 1.5 20 88 821 0015 (total length) pre-assembled on both sides, plastic hood, black, side entry 3 5 20 88 821 0030 10 20 88 821 0050 20 88 821 0100 15 30 20 88 821 0150 Cable lengths in m 1.5 20 88 861 0015 (total length) pre-assembled on both sides, metal hood, side entry 3 5 20 88 861 0030 20 88 861 0050 10 20 88 861 0100 15 30 20 88 861 0150 20 88 861 0300 Drawing male female à total length ß 20 88 821 0300 Other cable lengths and configurations on request Accessories Part-Number Cover black only for device side 09 12 008 5407 Components for male insert without sealing 09 12 008 5408 for female insert with sealing Crimping tool 09 99 000 0021 Use of crimping tool 09 99 000 0110 is also possible Cable 7 x 2.5 mm2 50 metres 100 metres 250 metres 500 metres on request HARTING Electric GmbH & Co. KG Wilhelm-Harting-Str. 1 • D-32339 Espelkamp 2002-03-27 • P.O. Box 14 73 • D-32328 Espelkamp Fon: +49/5772/47-97100 • Fax: +49/5772/47-495 • Harting.Electric@HARTING.com • www.HARTING.com Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: HARTING: 20888210015 20888210030 20888210050 20888210100 20888210150 20888210300 20888610015 20888610030 20888610050 20888610100 20888610150 20888610300
20888610030 价格&库存
很抱歉,暂时无法提供与“20888610030”相匹配的价格&库存,您可以联系我们找货
