N820-02M
N820-02M
    TRIPPLITE
    FIBERPATCHCABLELC/LCAQUA6FT
N820-02M 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States OM3 can support 40GBASE-SR4 / 100GBASE-SR10 in applicable parallel optics networks 10G Duplex Multimode 50/125 OM3 LSZH Fiber Optic Cable (LC/LC), Aqua, 2 m (6 ft.) MODEL NUMBER: N820-02M Highlights ● OM3 rated for 10G Ethernet applications ● Low-smoke, zero halogen (LSZH) aqua-colored jacket ● Max 10G distance of 300 m @ 850 nm ● Backward compatible with existing 50/125 fiber Package Includes ● Features ● OM3-rated 2 m (6 ft.) cable with LC/LC connectors ● 10G Ethernet speeds to 300 m @ 850 nm ● High speed, high bandwidth, low cost ● Ideal for fibre channel (SAN) applications ● IEEE 802.3ae and TIA LOMMF compliant ● Use with VCSEL and LED laser light sources ● Backward compatible with legacy LANs Specifications OVERVIEW UPC Code 037332134660 Technology Multimode Optical Mode OM3 PHYSICAL Cable Jacket Color Aqua Connector Color White; Aqua Cable Jacket Material LSZH Cable Jacket Rating OFNR 1/3 N820-02M 10G Duplex Multimode Fiber Optic Cable (LC/LC), Aqua, 2 m 1000 Eaton Boulevard Cleveland, OH 44122 United States Clad Diameter (microns) 125 Core Diameter (microns) 50 Number of Fibers 2 Cable Length (ft.) 6.6 Cable Length (m) 2.01 Cable Length (in.) 78.7 Minimum Bend Radius 20MM (Dynamic); 10MM (Static) Shipping Dimensions (hwd / in.) 9.00 x 7.00 x 0.50 Shipping Dimensions (hwd / cm) 22.86 x 17.78 x 1.27 Shipping Weight (lbs.) 0.06 Shipping Weight (kg) 0.03 ENVIRONMENTAL Operating Temperature Range -4 to 140 °F (-20 to 60 °C) Storage Temperature Range -4 to 140 °F (-20 to 60 °C) Operating Humidity Range 5% to 85% RH, Non-Condensing Storage Humidity Range 35% to 65% RH, Non-Condensing COMMUNICATIONS Network Compatibility 1 Gbps (Gigabit); 10 Gbps; 25 Gbps; 40 Gbps; 100 Gbps Attenuation @ 850NM 3.0dB/Km Insertion Loss 0.20dB CONNECTIONS Side A - Connector 1 LC DUPLEX (MALE) Side B - Connector 1 LC DUPLEX (MALE) Endface Polish PC FEATURES & SPECIFICATIONS Push/Pull Tabs No Breakout No Trunk No STANDARDS & COMPLIANCE Product Compliance RoHS; REACH WARRANTY & SUPPORT 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States Product Warranty Period (Worldwide) Lifetime limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
N820-02M 价格&库存
很抱歉,暂时无法提供与“N820-02M”相匹配的价格&库存,您可以联系我们找货
N820-02M
  • 1+230.839791+29.90183
  • 10+196.1823310+25.41248
  • 25+183.8947125+23.82080
  • 50+175.1203550+22.68421
  • 100+166.76774100+21.60226
  • 250+156.33749250+20.25118
  • 500+148.88636500+19.28599
库存:225
