N820-20M
N820-20M
    TRIPPLITE
    N820-20M
N820-20M 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States OM3 can support 40GBASE-SR4 / 100GBASE-SR10 in applicable parallel optics networks 10Gb Duplex Multimode 50/125 OM3 LSZH Fiber Patch Cable, (LC/LC) - Aqua, 20M (65-ft) MODEL NUMBER: N820-20M Highlights ● Designed for 10-Gig Ethernet applications...OM3 Rated ● Backward compatible with existing 50/125 fiber ● Max 10Gb distance of 300 meters @850nm ● Low-Smoke, Zero Halogen (LSZH) Aqua jacket Package Includes 20 meter Duplex Multimode 50/125 Aqua OM3 Fiber Patch Cable, LC/LC Description Tripp Lite introduces it's new OM3 Laser-Optimized Multimode Fiber (LOMMF) "Aqua" cables, for use with 10Gb Ethernet applications. These new technology, 50/125um, LC/LC Fiber Optic cables, provide nearly four times the bandwidth over conventional 62.5um multimode fiber, with performance rivaling that of Single mode cable, at a much reduced cost. LOMMF cable allows 10Gb serial transmission over extended distances in the 850nm wavelength window, where low-cost Vertical Cavity Surface Emitting Lasers (VCSELs) enable a cost-effective, high-bandwidth solution. LOMMF is ideally suited for LAN's, SAN's, and high-speed parallel interconnects for head-ends, central offices, and data centers. Features ● 20 Meter ( 66ft ) LC/LC 10Gb Fiber Patch Cable, OM3 Rated ● 10gb Ethernet speed to 300 meters @850nm ● Use with VCSEL and LED laser light sources ● High-Speed, High-Bandwidth, Low-Cost ● Backward compatible with legacy LAN's ● Ideal for Fibre Channel (SAN) applications ● IEEE 802.3ae and TIA LOMMF compliant Specifications OVERVIEW UPC Code 037332138453 Technology Multimode Optical Mode OM3 1/3 1000 Eaton Boulevard Cleveland, OH 44122 United States PHYSICAL Cable Jacket Color Aqua Connector Color White Cable Jacket Material LSZH Cable Jacket Rating OFNR Clad Diameter (microns) 125 Core Diameter (microns) 50 Number of Fibers 2 Cable Length (ft.) 65.6 Cable Length (m) 20.00 Cable Length (in.) 787.4 Minimum Bend Radius 20MM (Dynamic); 10MM (Static) Shipping Dimensions (hwd / in.) 9.00 x 7.00 x 0.50 Shipping Dimensions (hwd / cm) 22.86 x 17.78 x 1.27 Shipping Weight (lbs.) 0.32 Shipping Weight (kg) 0.15 ENVIRONMENTAL Operating Temperature Range -4 to 140 °F (-20 to 60 °C) Storage Temperature Range -4 to 140 °F (-20 to 60 °C) Operating Humidity Range 5% to 85% RH, Non-Condensing Storage Humidity Range 35% to 65% RH, Non-Condensing COMMUNICATIONS Network Compatibility 1 Gbps (Gigabit); 10 Gbps; 25 Gbps; 40 Gbps; 100 Gbps Attenuation @ 850NM 3.0dB/Km Insertion Loss 0.20dB CONNECTIONS Side A - Connector 1 LC DUPLEX (MALE) Side B - Connector 1 LC DUPLEX (MALE) Endface Polish PC FEATURES & SPECIFICATIONS Push/Pull Tabs No Breakout No 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States Trunk No STANDARDS & COMPLIANCE Product Compliance RoHS; REACH WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
N820-20M 价格&库存
很抱歉,暂时无法提供与“N820-20M”相匹配的价格&库存,您可以联系我们找货
