N370-01M
N370-01M
    TRIPPLITE
    N370-01M
N370-01M 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Duplex Singlemode 9/125 Fiber Patch Cable (LC/LC), 1M (3 ft.) MODEL NUMBER: N370-01M Highlights ● Premium PVC 9/125 micron singlemode patch cables ● Attenuation loss meets or exceeds the latest industry standards ● Twice the bandwidth throughput of multimode cable System Requirements ● Any fiber optic hardware or NIC card requiring singlemode duplex cable with LC/LCconnectors Package Includes ● Features ● Manufactured from 9/125 duplex (zipcord) fiber ● PVC jacket ● Length: 1-meter ( 3ft ) Connectors: 2 LC and 2 LC connectors on each end ● Insertion loss testing performed on every connector (0.2db typical) and provided with cable ● Beveled edge on ends of glass makes insertion of plug a breeze ● Fiber made from glass (not a polymer) ● Fiber optic distributed data interface (FDDI) rated ● OFNR (riser rated) Specifications OVERVIEW UPC Code 037332122797 Technology Singlemode Optical Mode OS2 PHYSICAL Cable Jacket Color Yellow Connector Color Blue; White Cable Jacket Material LSZH Cable Jacket Rating OFNR 1/3 1-meter ( 3ft ) Duplex Singlemode Fiber Patch Cable, LC/LC 1000 Eaton Boulevard Cleveland, OH 44122 United States Clad Diameter (microns) 125 Core Diameter (microns) 9 Number of Fibers 2 Cable Length (ft.) 3.3 Cable Length (m) 1.01 Cable Length (in.) 39.4 Minimum Bend Radius 20MM (Dynamic); 10MM (Static) Shipping Dimensions (hwd / in.) 9.00 x 7.00 x 0.50 Shipping Dimensions (hwd / cm) 22.86 x 17.78 x 1.27 Shipping Weight (lbs.) 0.04 Shipping Weight (kg) 0.02 ENVIRONMENTAL Operating Temperature Range -4 to 140 °F (-20 to 60 °C) Storage Temperature Range -4 to 140 °F (-20 to 60 °C) Operating Humidity Range 5% to 85% RH, Non-Condensing Storage Humidity Range 35% to 65% RH, Non-Condensing COMMUNICATIONS Network Compatibility 1 Gbps (Gigabit); 10 Gbps; 25 Gbps; 40 Gbps; 100 Gbps; 400 Gbps Attenuation @ 1310NM 0.36dB/Km Attenuation @ 1550NM 0.22dB/Km Insertion Loss 0.30dB CONNECTIONS Side A - Connector 1 LC DUPLEX (MALE) Side B - Connector 1 LC DUPLEX (MALE) Endface Polish UPC FEATURES & SPECIFICATIONS Push/Pull Tabs No Breakout No Trunk No STANDARDS & COMPLIANCE Product Compliance RoHS; REACH 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
N370-01M 价格&库存
很抱歉,暂时无法提供与“N370-01M”相匹配的价格&库存,您可以联系我们找货
