N820-25M
N820-25M
    TRIPPLITE
    FIBERPATCHCABLLC/LCAQUA82'
N820-25M 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States OM3 can support 40GBASE-SR4 / 100GBASE-SR10 in applicable parallel optics networks 10Gb Duplex Multimode 50/125 OM3 LSZH Fiber Patch Cable, (LC/LC) - Aqua, 25M (82 ft.) Highlights ● 25 Meter LC/LC 50/125 10Gb Aqua Fiber Patch Cable...OM3 Rated ● Designed for 10-Gig Ethernet applications ● Backward compatible with existing 50/125 fiber ● Max 10Gb distance of 300 meters @850nm ● Low-Smoke, Zero Halogen (LSZH) Aqua jacket MODEL NUMBER: N820-25M Package Includes ● Features ● 25 Meter LC/LC 50/125 10Gb Aqua Fiber Patch Cable, OM3 Rated ● 10gb Ethernet speed to 300 meters @850nm ● Use with VCSEL and LED laser light sources ● High-Speed, High-Bandwidth, Low-Cost ● Backward compatible with legacy LAN's ● Ideal for Fibre Channel (SAN) applications ● IEEE 802.3ae and TIA LOMMF compliant Specifications OVERVIEW UPC Code 037332149923 Technology Multimode Optical Mode OM3 PHYSICAL Cable Jacket Color Aqua Connector Color White Cable Jacket Material LSZH Cable Jacket Rating OFNR 1/3 25 meter Duplex Multimode 50/125 OM3 Aqua Fiber Patch Cable, LC/LC 1000 Eaton Boulevard Cleveland, OH 44122 United States Clad Diameter (microns) 125 Core Diameter (microns) 50 Number of Fibers 2 Cable Length (ft.) 82 Cable Length (m) 25.00 Cable Length (in.) 984.3 Minimum Bend Radius 20MM (Dynamic); 10MM (Static) Shipping Dimensions (hwd / in.) 12.00 x 10.50 x 0.50 Shipping Dimensions (hwd / cm) 30.48 x 26.67 x 1.27 Shipping Weight (lbs.) 0.39 Shipping Weight (kg) 0.18 ENVIRONMENTAL Operating Temperature Range -4 to 140 °F (-20 to 60 °C) Storage Temperature Range -4 to 140 °F (-20 to 60 °C) Operating Humidity Range 5% to 85% RH, Non-Condensing Storage Humidity Range 35% to 65% RH, Non-Condensing COMMUNICATIONS Network Compatibility 1 Gbps (Gigabit); 10 Gbps; 25 Gbps; 40 Gbps; 100 Gbps Attenuation @ 850NM 3.0dB/Km Insertion Loss 0.20dB CONNECTIONS Side A - Connector 1 LC DUPLEX (MALE) Side B - Connector 1 LC DUPLEX (MALE) Endface Polish PC FEATURES & SPECIFICATIONS Push/Pull Tabs No Breakout No Trunk No STANDARDS & COMPLIANCE Product Compliance RoHS; REACH WARRANTY & SUPPORT 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States Product Warranty Period (Worldwide) Lifetime limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
N820-25M 价格&库存
很抱歉,暂时无法提供与“N820-25M”相匹配的价格&库存,您可以联系我们找货
N820-25M
  • 1+749.677861+96.96658
