N520-02M
N520-02M
    TRIPPLITE
    N520-02M
N520-02M 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Duplex Multimode 50/125 Fiber Patch Cable (LC/LC), 2M (6 ft.) MODEL NUMBER: N520-02M Highlights ● Premium PVC 50/125 multimode patch cables ● Attenuation loss meets or exceeds the latest industry standards ● Higher bandwidth optimized for gigabit and 10Gbps networks ● Backward compatible with 62.5 micron fiber ● Built-in headroom for future applications System Requirements ● Any fiber optic hardware or NIC card requiring multimode duplex cable with LC/LC connectors Package Includes ● Features ● Constructed with 50/125 micron cable ● Length - 2M ● Use on fiber and fibre channel installations ● LC male to LC male connectors ● Higher bandwidth optimized for gigabit and 10Gbps networks ● Backward compatible with 62.5 micron fiber ● Built-in headroom for future applications ● Number of fibers: 2 ● Fiber type: all glass graded index ● Core diameter: two 50+/-3 microns ● CLAD diameter: 125+/-2 microns ● Primary coating diameter: 245+/-15 microns ● Primary coating material: acrylate ● Secondary coating diameter: 900+/-50 microns ● Secondary coating material: PVC ● Attenuation @850NM: 3.5DB/KM maximum, @1300NM: 1.0DB/KM maximum ● Bandwidth @850NM: 220 MHz-KM minimum, @1300NM: 600 MHz-KM minimum ● Numeric aperture: .275 nominal ● Proof test level: 100,000 PSI ● Insertion loss testing performed on every connector (0.2db typical) and provided with cable ● Beveled edge on ends of glass makes insertion of plug a breeze Specifications 1/3 2M duplex MMF cable LC/LC 50/125 fiber 1000 Eaton Boulevard Cleveland, OH 44122 United States OVERVIEW UPC Code 037332119513 Technology Multimode Optical Mode OM2 PHYSICAL Cable Jacket Color Orange Connector Color Gray Cable Jacket Material LSZH Cable Jacket Rating OFNR Clad Diameter (microns) 125 Core Diameter (microns) 50 Number of Fibers 2 Cable Length (ft.) 6.6 Cable Length (m) 2.01 Cable Length (in.) 78.7 Minimum Bend Radius 20MM (Dynamic); 10MM (Static) Shipping Dimensions (hwd / in.) 9.00 x 7.00 x 0.50 Shipping Dimensions (hwd / cm) 22.86 x 17.78 x 1.27 Shipping Weight (lbs.) 0.05 Shipping Weight (kg) 0.02 ENVIRONMENTAL Operating Temperature Range -4 to 140 °F (-20 to 60 °C) Storage Temperature Range -4 to 140 °F (-20 to 60 °C) Operating Humidity Range 5% to 85% RH, Non-Condensing Storage Humidity Range 35% to 65% RH, Non-Condensing COMMUNICATIONS Network Compatibility 1 Gbps (Gigabit); 10 Gbps; 25 Gbps Attenuation @ 850NM 3.0dB/Km Insertion Loss 0.20dB CONNECTIONS Side A - Connector 1 LC DUPLEX (MALE) Side B - Connector 1 LC DUPLEX (MALE) 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States Endface Polish PC FEATURES & SPECIFICATIONS Push/Pull Tabs No Breakout No Trunk No STANDARDS & COMPLIANCE Product Compliance RoHS; REACH WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
N520-02M
物料型号:N520-02M
器件简介: - 该光纤跳线采用50/125微米光纤,长度为2米。 - 适用于光纤和光纤通道安装。 - 连接器类型为LC公头到LC公头。 - 优化带宽,适用于千兆和10Gbps网络。 - 与62.5微米光纤向后兼容。 - 内置余量,适用于未来应用。
引脚分配: - 光纤数量:2根 - 光纤类型:全玻璃梯度折射率 - 核心直径:两个50±3微米 - 包层直径:125±2微米 - 主涂层直径:245±15微米 - 主涂层材料:丙烯酸 - 次涂层直径:900±50微米 - 次涂层材料:PVC
参数特性: - 在850纳米处的衰减:最大3.5分贝/公里,1300纳米处:最大1.0分贝/公里 - 在850纳米处的带宽:最小220兆赫兹-公里,1300纳米处:最小600兆赫兹-公里 - 数值孔径:0.275标称 - 压力测试级别:100,000 PSI - 每个连接器都进行了插入损耗测试(典型值0.2分贝),并随电缆提供
功能详解: - 插入损耗测试在每个连接器上执行,并随电缆提供。 - 玻璃末端的斜面使得插入插头变得轻松。
应用信息: - 适用于任何需要LC/LC连接器的多模双工光纤电缆的光纤硬件或NIC卡。
封装信息: - UPC代码:037332119513 - 技术:多模 - 光模式:OM2 - 物理特性: - 电缆外套颜色:橙色 - 连接器颜色:灰色 - 电缆外套材料:LSZH - 包层直径(微米):125 - 核心直径(微米):50 - 光纤数量:2 - 电缆长度(英尺):6.6 - 电缆长度(米):2.01 - 电缆长度(英寸):78.7 - 最小弯曲半径:20毫米(动态);10毫米(静态) - 运输尺寸(高宽深/英寸):9.00x7.00x0.50 - 运输尺寸(高宽深/厘米):22.86x17.78x1.27 - 运输重量(磅):0.05 - 运输重量(公斤):0.02
环境信息: - 工作温度范围:-4至140华氏度(-20至60摄氏度) - 存储温度范围:-4至140华氏度(-20至60摄氏度) - 工作湿度范围:5%至85% RH,无冷凝 - 存储湿度范围:35%至65% RH,无冷凝
通信信息: - 网络兼容性:1 Gbps(千兆);10 Gbps;25 Gbps - 在850纳米处的衰减:3.0分贝/公里 - 插入损耗:0.20分贝
连接信息: - A端-连接器1:LC双工(公头) - B端-连接器1:LC双工(公头)
端面抛光:PC
特性与规格: - 推拉标签:无 - 分线:无 - 主干:无
标准与合规性: - 产品合规性:RoHS:REACH
保修与支持: - 产品保修期(全球):有限终身保修
N520-02M 价格&库存
很抱歉,暂时无法提供与“N520-02M”相匹配的价格&库存,您可以联系我们找货
N520-02M
  • 1+179.471961+23.33078
  • 10+152.5047910+19.82513
  • 25+142.9584725+18.58414
  • 50+136.1339150+17.69697
  • 100+129.64096100+16.85291
  • 250+121.53201250+15.79877
  • 500+118.99970500+15.46958
库存:47
