N504-02M
N504-02M
    TRIPPLITE
    DUPLEXFIBERPATCHCABLSC/ST6'
N504-02M 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Duplex Multimode 50/125 Fiber Patch Cable (SC/ST), 2M (6 ft.) MODEL NUMBER: N504-02M Highlights ● Premium PVC 50/125µm multimode patch cables ● Attenuation loss meets or exceeds the latest industry standards Package Includes ● Description Tripp Lite's 2M (6.56-ft.) multimode duplex fiber optic SC/ST patch cable is manufactured from 50/125 zipcord fiber. The cable has ST to SC connectors, a PVC jacket and is FDDI and OFNR rated. Duplex multimode fiber is most commonly used in LAN applications. Features ● Manufactured from 50/125 duplex (zipcord) fiber ● PVC jacket ● Length: 2M (6.56-ft.) - Connectors: 2 ST to 2 SC connectors ● Insertion loss testing performed on every connector (0.2db typical) and provided with cable ● Beveled edge on ends of glass makes insertion of plug a breeze ● Fiber made from glass (not a polymer) ● Fiber optic distributed data interface (FDDI) rated ● OFNR (riser rated) Specifications OVERVIEW UPC Code 037332134806 Technology Multimode Optical Mode OM2 PHYSICAL Cable Jacket Color Orange 1/3 2M (6.56-ft.) duplex MMF cable ST/SC 50/125 fiber 1000 Eaton Boulevard Cleveland, OH 44122 United States Connector Color Beige; Black Cable Jacket Material LSZH Cable Jacket Rating OFNR Clad Diameter (microns) 125 Core Diameter (microns) 50 Number of Fibers 2 Cable Length (ft.) 6.6 Cable Length (m) 2.01 Cable Length (in.) 78.7 Minimum Bend Radius 20MM (Dynamic); 10MM (Static) Shipping Dimensions (hwd / in.) 0.25 x 5.60 x 5.60 Shipping Dimensions (hwd / cm) 0.64 x 14.22 x 14.22 Shipping Weight (lbs.) 0.10 Shipping Weight (kg) 0.05 ENVIRONMENTAL Operating Temperature Range -4 to 140 °F (-20 to 60 °C) Storage Temperature Range -4 to 140 °F (-20 to 60 °C) Operating Humidity Range 5% to 85% RH, Non-Condensing Storage Humidity Range 35% to 65% RH, Non-Condensing COMMUNICATIONS Network Compatibility 1 Gbps (Gigabit); 10 Gbps Attenuation @ 850NM 3.0dB/Km Insertion Loss ST0.20dB; SC0.20dB CONNECTIONS Side A - Connector 1 SC DUPLEX (MALE) Side B - Connector 1 ST DUPLEX (MALE) Endface Polish PC FEATURES & SPECIFICATIONS Push/Pull Tabs No Breakout No Trunk No STANDARDS & COMPLIANCE 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States Product Compliance RoHS; REACH WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
N504-02M 价格&库存
很抱歉,暂时无法提供与“N504-02M”相匹配的价格&库存,您可以联系我们找货
N504-02M
  • 1+152.332171+19.73235
