N308-006
N308-006
    TRIPPLITE
    N308-006
N308-006 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Duplex Multimode 62.5/125 Fiber Patch Cable (MTRJ/ST), 2M (6 ft.) MODEL NUMBER: N308-006 Highlights ● Premium PVC 62.5/125µm multimode patch cables ● Attenuation loss meets or exceeds the latest industry standards ● Loop-back cables provide an easier, "single-person" solution for testing fiber optic cable systems System Requirements ● Any fiber optic hardware or NIC card requiring multimode duplex cable with MT-RJ/ST connectors Package Includes ● Features ● Manufactured from 62.5/125 duplex (zipcord) fiber ● PVC jacket ● Length: 6-ft. (1.83 m) Connectors: MTRJ to 2 ST ● Insertion loss testing performed on every connector (0.2db typical) and provided with cable ● Beveled edge on ends of glass makes insertion of plug a breeze ● Fiber made from glass (not a polymer) ● Color coded shrouds identify transmit and receive ● Duplex multimode fiber is most commonly used in LAN applications where links are typically 10-ft. (3.05 m) or less ● Fiber optic distributed data interface (FDDI) rated ● OFNR (riser rated) Specifications OVERVIEW UPC Code 037332042026 Technology Multimode Optical Mode OM1 PHYSICAL Cable Jacket Color Orange Connector Color Black 1/3 6-ft. (1.83 m) Duplex MMF Cable MTRJ/ST 62.5/125 Fiber 1000 Eaton Boulevard Cleveland, OH 44122 United States Cable Jacket Material LSZH Cable Jacket Rating OFNR Clad Diameter (microns) 125 Core Diameter (microns) 62.5 Number of Fibers 2 Cable Length (ft.) 6 Cable Length (m) 1.83 Cable Length (in.) 72 Minimum Bend Radius 20MM (Dynamic); 10MM (Static) Shipping Dimensions (hwd / in.) 9.00 x 7.00 x 0.50 Shipping Dimensions (hwd / cm) 22.86 x 17.78 x 1.27 Shipping Weight (lbs.) 0.06 Shipping Weight (kg) 0.03 ENVIRONMENTAL Operating Temperature Range -4 to 140 °F (-20 to 60 °C) Storage Temperature Range -4 to 140 °F (-20 to 60 °C) Operating Humidity Range 5% to 85% RH, Non-Condensing Storage Humidity Range 35% to 65% RH, Non-Condensing COMMUNICATIONS Network Compatibility 1 Gbps (Gigabit) Attenuation @ 850NM 3.0dB/Km Insertion Loss MTRJ0.50dB; ST0.20dB CONNECTIONS Side A - Connector 1 MTRJ DUPLEX (MALE) Side B - Connector 1 ST DUPLEX (MALE) Endface Polish PC FEATURES & SPECIFICATIONS Push/Pull Tabs No Breakout No Trunk No STANDARDS & COMPLIANCE Product Compliance RoHS; REACH 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
N308-006 价格&库存
很抱歉,暂时无法提供与“N308-006”相匹配的价格&库存,您可以联系我们找货
N308-006
  • 1+177.989221+23.14350
  • 10+162.7939810+21.16770
  • 25+157.5012525+20.47950
  • 50+153.7451350+19.99110
  • 100+150.15973100+19.52490
  • 250+145.89141250+18.96990
  • 500+142.56211500+18.53700
