N310-003
N310-003
    TRIPPLITE
    CABLE FIBER OPTIC DUPLEX 3'
N310-003 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Duplex Multimode 62.5/125 Fiber Patch Cable (MTRJ/SC), 1M (3 ft.) MODEL NUMBER: N310-003 Highlights ● Premium PVC 62.5/125µm multimode patch cables ● Attenuation loss meets or exceeds the latest industry standards System Requirements ● Any fiber optic hardware or NIC card requiring multimode duplex cable with MT-RJ/SC connectors Package Includes ● Description Tripp Lite's 3-ft. (0.91 m) multimode duplex fiber optic MTRJ/SC patch cable is manufactured from 62.5/125 zipcord fiber. The cable has MTRJ to SC connectors, a PVC jacket and is FDDI and OFNR rated. Duplex multimode fiber is most commonly used in LAN applications. Features ● Manufactured from 62.5/125 duplex (zipcord) fiber ● PVC jacket ● Length: 3-ft. (0.91 m) Connectors: MTRJ to 2 SC ● Insertion loss testing performed on every connector (0.2db typical) and provided with cable ● Beveled edge on ends of glass makes insertion of plug a breeze ● Fiber made from glass (not a polymer) ● Color coded shrouds identify transmit and receive ● Duplex multimode fiber is most commonly used in LAN applications where links are typically 10-ft. (3.05 m) or less ● Fiber optic distributed data interface (FDDI) rated ● OFNR (riser rated) Specifications OVERVIEW UPC Code 037332042064 Technology Multimode Optical Mode OM1 1/3 3-ft. (0.91 m) Duplex MMF Cable MTRJ/SC 62.5/125 Fiber 1000 Eaton Boulevard Cleveland, OH 44122 United States PHYSICAL Cable Jacket Color Orange Connector Color White; Black Cable Jacket Material LSZH Cable Jacket Rating OFNR Clad Diameter (microns) 125 Core Diameter (microns) 62.5 Number of Fibers 2 Cable Length (ft.) 3 Cable Length (m) 0.91 Cable Length (in.) 36 Minimum Bend Radius 20MM (Dynamic); 10MM (Static) Shipping Dimensions (hwd / in.) 0.25 x 6.00 x 6.00 Shipping Dimensions (hwd / cm) 0.64 x 15.24 x 15.24 Shipping Weight (lbs.) 0.05 Shipping Weight (kg) 0.02 ENVIRONMENTAL Operating Temperature Range -4 to 140 °F (-20 to 60 °C) Storage Temperature Range -4 to 140 °F (-20 to 60 °C) Operating Humidity Range 5% to 85% RH, Non-Condensing Storage Humidity Range 35% to 65% RH, Non-Condensing COMMUNICATIONS Network Compatibility 1 Gbps (Gigabit); 10 Gbps Attenuation @ 850NM 3.0dB/Km Insertion Loss MTRJ0.50dB; SC0.20dB CONNECTIONS Side A - Connector 1 MTRJ DUPLEX (MALE) Side B - Connector 1 SC DUPLEX (MALE) Endface Polish PC FEATURES & SPECIFICATIONS Push/Pull Tabs No Breakout No 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States Trunk No STANDARDS & COMPLIANCE Product Compliance RoHS; REACH WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
N310-003 价格&库存
很抱歉,暂时无法提供与“N310-003”相匹配的价格&库存,您可以联系我们找货
