1000 Eaton Boulevard
Cleveland, OH 44122
United States
Duplex Multimode 62.5/125 Fiber Patch Cable
(LC/SC), 3M (10 ft.)
MODEL NUMBER: N316-03M
Highlights
Premium PVC 62.5/125µm
multimode patch cables
Attenuation loss meets or
exceeds the latest industry
standards
System Requirements
Any fiber optic hardware or NIC
card requiring multimode duplex
cable with SC/LC connectors
Package Includes
Features
Manufactured from 62.5/125 duplex (zipcord) fiber
PVC jacket
Length: 3-meter connectors: 2 SC/LC connectors on each end
Insertion loss testing performed on every connector (0.2db typical) and provided with cable
Beveled edge on ends of glass makes insertion of plug a breeze
Fiber made from glass (not a polymer)
Duplex multimode fiber is most commonly used in LAN applications where links are typically 10-ft. (3.05
m) or less
Fiber optic distributed data interface (FDDI) rated
OFNR (riser rated)
Specifications
OVERVIEW
UPC Code
037332097866
Technology
Multimode
Optical Mode
OM1
PHYSICAL
Cable Jacket Color
Orange
Connector Color
White; Beige
Cable Jacket Material
LSZH
1/3
3M Duplex MMF Cable LC/SC
62.5/125 Fiber
Cleveland, OH 44122
United States
Cable Jacket Rating
OFNR
Clad Diameter (microns)
125
Core Diameter (microns)
62.5
Number of Fibers
2
Cable Length (ft.)
9.8
Cable Length (m)
2.99
Cable Length (in.)
118.1
Minimum Bend Radius
20MM (Dynamic); 10MM (Static)
Shipping Dimensions (hwd / in.)
0.25 x 6.30 x 8.00
Shipping Dimensions (hwd / cm)
0.64 x 16.00 x 20.32
Shipping Weight (lbs.)
0.10
Shipping Weight (kg)
0.05
ENVIRONMENTAL
Operating Temperature Range
-4 to 140 °F (-20 to 60 °C)
Storage Temperature Range
Operating Humidity Range
5% to 85% RH, Non-Condensing
Storage Humidity Range
35% to 65% RH, Non-Condensing
COMMUNICATIONS
Network Compatibility
1 Gbps (Gigabit); 10 Gbps
Attenuation @ 850NM
3.0dB/Km
Insertion Loss
LC0.20dB; SC0.20dB
CONNECTIONS
Side A - Connector 1
LC DUPLEX (MALE)
Side B - Connector 1
SC DUPLEX (MALE)
Endface Polish
PC
FEATURES & SPECIFICATIONS
Push/Pull Tabs
No
Breakout
No
Trunk
No
STANDARDS & COMPLIANCE
Product Compliance
RoHS; REACH
2/3
Cleveland, OH 44122
United States
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
Lifetime limited warranty
© 2022 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
3/3
很抱歉,暂时无法提供与“N316-03M”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+196.811691+25.42617
