N516-02M
N516-02M
    TRIPPLITE
    N516-02M
N516-02M 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Duplex Multimode 50/125 Fiber Patch Cable (LC/SC), 2M (6 ft.) MODEL NUMBER: N516-02M Highlights ● Multimode duplex (50µ/125) fiber patch cable ● Attenuation loss meets or exceeds the latest industry standards ● Higher bandwidth optimized for gigabit and 10Gbps networks ● Backward compatible with 62.5 micron fiber ● Built-in headroom for future applications System Requirements ● Any fiber optic hardware or NIC card requiring multimode duplex cable with LC/SC connectors Package Includes ● Features ● Constructed with 50/125 micron cable ● Length - 2M ● Use on fiber and fibre channel installations ● SC male to LC male connectors ● Higher bandwidth optimized for gigabit and 10Gbps networks ● Backward compatible with 62.5 micron fiber ● Built-in headroom for future applications ● Number of fibers: 2 ● Fiber type: all glass graded index ● Core diameter: two 50+/-3 microns ● CLAD diameter: 125+/-2 microns ● Primary coating diameter: 245+/-15 microns ● Primary coating material: acrylate ● Secondary coating diameter: 900+/-50 microns ● Secondary coating material: PVC ● Attenuation @850NM: 3.5DB/KM maximum, @1300NM: 1.0DB/KM maximum ● Bandwidth @850NM: 220 MHz-KM minimum, @1300NM: 600 MHz-KM minimum ● Numeric aperture: .275 nominal ● Proof test level: 100,000 PSI ● Insertion loss testing performed on every connector (0.2db typical) and provided with cable ● Beveled edge on ends of glass makes insertion of plug a breeze Specifications 1/3 2M duplex MMF cable LC/SC 50/125 fiber 1000 Eaton Boulevard Cleveland, OH 44122 United States OVERVIEW UPC Code 037332119575 Technology Multimode Optical Mode OM2 PHYSICAL Cable Jacket Color Orange Connector Color White; Beige Cable Jacket Material LSZH Cable Jacket Rating OFNR Clad Diameter (microns) 125 Core Diameter (microns) 50 Number of Fibers 2 Cable Length (ft.) 6.6 Cable Length (m) 2.01 Cable Length (in.) 78.7 Minimum Bend Radius 20MM (Dynamic); 10MM (Static) Shipping Dimensions (hwd / in.) 9.00 x 7.00 x 0.50 Shipping Dimensions (hwd / cm) 22.86 x 17.78 x 1.27 Shipping Weight (lbs.) 0.04 Shipping Weight (kg) 0.02 ENVIRONMENTAL Operating Temperature Range -4 to 140 °F (-20 to 60 °C) Storage Temperature Range -4 to 140 °F (-20 to 60 °C) Operating Humidity Range 5% to 85% RH, Non-Condensing Storage Humidity Range 35% to 65% RH, Non-Condensing COMMUNICATIONS Network Compatibility 1 Gbps (Gigabit); 10 Gbps; 25 Gbps Attenuation @ 850NM 3.0dB/Km Insertion Loss LC0.20dB; SC0.20dB CONNECTIONS Side A - Connector 1 LC DUPLEX (MALE) Side B - Connector 1 SC DUPLEX (MALE) 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States Endface Polish PC FEATURES & SPECIFICATIONS Push/Pull Tabs No Breakout No Trunk No STANDARDS & COMPLIANCE Product Compliance RoHS; REACH WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
N516-02M 价格&库存
很抱歉,暂时无法提供与“N516-02M”相匹配的价格&库存,您可以联系我们找货
