N320-01M-RD
N320-01M-RD
    TRIPPLITE
    DUPLEXFIBERPATCHCABLE1M
N320-01M-RD 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Duplex Multimode 62.5/125 Fiber Patch Cable (LC/LC) - Red, 1M (3 ft.) MODEL NUMBER: N320-01M-RD Highlights ● Manufactured from 62.5/125 duplex (Zipcord) fiber with Red jacket ● Length: 1 meter Connectors: LC connector on each end ● Insertion loss testing performed on every connector (0.2dB typical) System Requirements ● Any fiber optic hardware or NIC card requiring multimode duplex cable with LC connectors Package Includes ● Features ● Manufactured from 62.5/125 duplex (zipcord) fiber ● Red PVC jacket ● Length: 1 meter Connectors: LC connector on each end ● Fiber made from glass (not a polymer) ● Fiber optic distributed data interface (FDDI)and OFNR rated Specifications OVERVIEW UPC Code 037332138590 Technology Multimode Optical Mode OM1 PHYSICAL Cable Jacket Color Red Connector Color Gray Cable Jacket Material LSZH Cable Jacket Rating OFNR Clad Diameter (microns) 125 Core Diameter (microns) 62.5 Number of Fibers 2 1/3 1M Duplex MMF Cable LC/LC 62.5/125 Micron Fiber Red Jacket 1000 Eaton Boulevard Cleveland, OH 44122 United States Cable Length (ft.) 3.3 Cable Length (m) 1.01 Cable Length (in.) 39.4 Minimum Bend Radius 20MM (Dynamic); 10MM (Static) Shipping Dimensions (hwd / in.) 9.00 x 7.00 x 0.50 Shipping Dimensions (hwd / cm) 22.86 x 17.78 x 1.27 Shipping Weight (lbs.) 0.03 Shipping Weight (kg) 0.01 ENVIRONMENTAL Operating Temperature Range -4 to 140 °F (-20 to 60 °C) Storage Temperature Range -4 to 140 °F (-20 to 60 °C) Operating Humidity Range 5% to 85% RH, Non-Condensing Storage Humidity Range 35% to 65% RH, Non-Condensing COMMUNICATIONS Network Compatibility 1 Gbps (Gigabit); 10 Gbps Attenuation @ 850NM 3.0dB/Km Insertion Loss 0.20dB CONNECTIONS Side A - Connector 1 LC DUPLEX (MALE) Side B - Connector 1 LC DUPLEX (MALE) Endface Polish PC FEATURES & SPECIFICATIONS Push/Pull Tabs No Breakout No Trunk No STANDARDS & COMPLIANCE Product Compliance RoHS; REACH WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
N320-01M-RD 价格&库存
很抱歉,暂时无法提供与“N320-01M-RD”相匹配的价格&库存,您可以联系我们找货
