1000 Eaton Boulevard
Cleveland, OH 44122
United States
OM3 can support 40GBASE-SR4 / 100GBASE-SR10 in applicable parallel optics networks
10Gb Duplex Multimode 50/125 OM3 LSZH Fiber
Patch Cable (SC/SC) - Aqua, 2M (6 ft.)
MODEL NUMBER: N806-02M
Highlights
Designed for 10-Gig Ethernet
applications...OM3 Rated
Backward compatible with
existing 50/125 fiber
Max 10Gb distance of 300
meters @850nm
Low-Smoke, Zero Halogen
(LSZH) Aqua jacket
Package Includes
Features
2M (6.56-ft.) SC/SC 10Gig, OM3 Rated
Use with VCSEL and LED laser light sources
High-Speed, High-Bandwidth, Low-Cost
Backward compatible with legacy LAN's
Ideal for Fibre Channel (SAN) applications
IEEE 802.3ae and TIA LOMMF compliant
10gb Ethernet speed to 300 meters @850nm
Specifications
OVERVIEW
UPC Code
037332134738
Technology
Multimode
Optical Mode
OM3
PHYSICAL
Cable Jacket Color
Aqua
Connector Color
Beige
Cable Jacket Material
LSZH
Cable Jacket Rating
OFNR
1/3
2M (6.56-ft.) Duplex Multimode
50/125 Aqua OM3 Fiber Patch
Cable, SC/SC
Cleveland, OH 44122
United States
Clad Diameter (microns)
125
Core Diameter (microns)
50
Number of Fibers
2
Cable Length (ft.)
6.6
Cable Length (m)
2.01
Cable Length (in.)
78.7
Minimum Bend Radius
20MM (Dynamic); 10MM (Static)
Shipping Dimensions (hwd / in.)
0.10 x 6.60 x 8.70
Shipping Dimensions (hwd / cm)
0.25 x 16.76 x 22.10
Shipping Weight (lbs.)
0.10
Shipping Weight (kg)
0.05
ENVIRONMENTAL
Operating Temperature Range
-4 to 140 °F (-20 to 60 °C)
Storage Temperature Range
Operating Humidity Range
5% to 85% RH, Non-Condensing
Storage Humidity Range
35% to 65% RH, Non-Condensing
COMMUNICATIONS
Network Compatibility
1 Gbps (Gigabit); 10 Gbps
Attenuation @ 850NM
3.0dB/Km
Insertion Loss
0.20dB
CONNECTIONS
Side A - Connector 1
SC DUPLEX (MALE)
Side B - Connector 1
SC DUPLEX (MALE)
Endface Polish
PC
FEATURES & SPECIFICATIONS
Push/Pull Tabs
No
Breakout
No
Trunk
No
STANDARDS & COMPLIANCE
Product Compliance
RoHS; REACH
WARRANTY & SUPPORT
2/3
Cleveland, OH 44122
United States
Product Warranty Period
(Worldwide)
Lifetime limited warranty
© 2022 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
3/3
很抱歉,暂时无法提供与“N806-02M”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+212.348431+26.62890
- 2+210.843662+26.44020
- 5+207.745635+26.05170
- 10+194.2027710+24.35340
- 25+188.0952125+23.58750
- 50+183.7579550+23.04360
- 100+177.29633100+22.23330
- 250+173.31314250+21.73380
- 500+172.42798500+21.62280
