N518-03M
N518-03M
    TRIPPLITE
    N518-03M
N518-03M 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Duplex Multimode 50/125 Fiber Patch Cable (LC/ST), 3M (10 ft.) MODEL NUMBER: N518-03M Highlights ● Premium PVC multimode patch cables ● Attenuation loss meets or exceeds the latest industry standards ● Perfect for use with Fibre Channel Controller Cards and Switches System Requirements ● Any fiber optic hardware or NIC card requiring multimode duplex cable with LC/ST connectors Package Includes ● Features ● Constructed with 50/125 micron cable ● Length - 3 Meter ( 10ft ) ● Use on fiber and fibre channel installations ● LC male to ST male connectors ● Higher bandwidth optimized for gigabit and 10Gbps networks ● Backward compatible with 62.5 micron fiber ● Built-in headroom for future applications Specifications OVERVIEW UPC Code 037332132741 Technology Multimode Optical Mode OM2 PHYSICAL Cable Jacket Color Orange Connector Color Gray; Red; Black Cable Jacket Material LSZH Cable Jacket Rating OFNR Clad Diameter (microns) 125 1/3 3 Meter( 10ft ) duplex MMF cable LC/ST 50/125 fiber 1000 Eaton Boulevard Cleveland, OH 44122 United States Core Diameter (microns) 50 Number of Fibers 2 Cable Length (ft.) 9.8 Cable Length (m) 2.99 Cable Length (in.) 118.1 Minimum Bend Radius 20MM (Dynamic); 10MM (Static) Shipping Dimensions (hwd / in.) 0.25 x 6.50 x 7.00 Shipping Dimensions (hwd / cm) 0.64 x 16.51 x 17.78 Shipping Weight (lbs.) 0.05 Shipping Weight (kg) 0.02 ENVIRONMENTAL Operating Temperature Range -4 to 140 °F (-20 to 60 °C) Storage Temperature Range -4 to 140 °F (-20 to 60 °C) Operating Humidity Range 5% to 85% RH, Non-Condensing Storage Humidity Range 35% to 65% RH, Non-Condensing COMMUNICATIONS Network Compatibility 1 Gbps (Gigabit); 10 Gbps; 25 Gbps Attenuation @ 850NM 3.0dB/Km Insertion Loss LC0.20dB; ST0.20dB CONNECTIONS Side A - Connector 1 LC DUPLEX (MALE) Side B - Connector 1 ST DUPLEX (MALE) Endface Polish PC FEATURES & SPECIFICATIONS Push/Pull Tabs No Breakout No Trunk No STANDARDS & COMPLIANCE Product Compliance RoHS; REACH WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
N518-03M
物料型号:N518-03M
器件简介: - 该光纤跳线采用50/125微米光纤,长度为3米(10英尺)。 - 适用于光纤和光纤通道安装。 - 连接器类型为LC公对ST公。 - 提供更高的带宽,优化用于千兆和10Gbps网络。 - 向后兼容62.5微米光纤。 - 为未来应用内置余量。
引脚分配: - 连接器1(侧A):LC双工(公) - 连接器1(侧B):ST双工(公)
参数特性: - 光纤类型:多模 - 光模式:OM2 - 光纤外径:125微米 - 光纤芯径:50微米 - 光纤数量:2 - 光纤长度:9.8英尺(2.99米) - 最小弯曲半径:动态20毫米;静态10毫米 - 护套颜色:橙色 - 连接器颜色:灰色、红色、黑色 - 护套材料:LSZH - 护套等级:OFNR - 操作温度范围:-4至140华氏度(-20至60摄氏度) - 存储温度范围:-4至140华氏度(-20至60摄氏度) - 操作湿度范围:5%至85% RH,无冷凝 - 存储湿度范围:35%至65% RH,无冷凝 - 网络兼容性:1 Gbps(千兆);10 Gbps;25 Gbps - 850纳米下衰减:3.0dB/Km - 插入损耗:LC 0.20dB: ST 0.20dB - 端面抛光:PC
功能详解: - 产品符合RoHS和REACH标准。 - 提供终身有限保修。
应用信息: - 适用于任何需要LC/ST连接器的多模双工光纤电缆的光纤硬件或NIC卡。
封装信息: - 包装包括:3米(10英尺)双工MMF电缆LC/ST 50/125光纤。
N518-03M 价格&库存
很抱歉,暂时无法提供与“N518-03M”相匹配的价格&库存,您可以联系我们找货
