N310-05M
N310-05M
    TRIPPLITE
    CABLE FIBER OPTIC DUPLEX 16'
N310-05M 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Duplex Multimode 62.5/125 Fiber Patch Cable (MTRJ/SC), 5M (16 ft.) MODEL NUMBER: N310-05M Highlights ● Premium PVC 62.5/125µm multimode patch cables ● Attenuation loss meets or exceeds the latest industry standards System Requirements ● Any fiber optic hardware or NIC card requiring Multimode Duplex cable with MT-RJ/SC connectors Package Includes ● Features ● Manufactured from 62.5/125 duplex (zipcord) fiber ● PVC jacket ● Length: 5-meters (16.4ft) Connectors: MTRJ to 2 SC ● Insertion loss testing performed on every connector (0.2db typical) and provided with cable ● Beveled edge on ends of glass makes insertion of plug a breeze ● Fiber made from glass (not a polymer) ● Color coded shrouds identify transmit and receive ● Duplex multimode fiber is most commonly used in LAN applications where links are typically 10-ft. (3.05 m) or less ● Fiber optic distributed data interface (FDDI) rated ● OFNR (riser rated) Specifications OVERVIEW UPC Code 037332123671 Technology Multimode Optical Mode OM1 PHYSICAL Cable Jacket Color Orange Connector Color White; Black 1/3 5-meter Duplex MMF Cable MTRJ/SC 62.5/125 Fiber 1000 Eaton Boulevard Cleveland, OH 44122 United States Cable Jacket Material LSZH Cable Jacket Rating OFNR Clad Diameter (microns) 125 Core Diameter (microns) 62.5 Number of Fibers 2 Cable Length (ft.) 16.4 Cable Length (m) 5.00 Cable Length (in.) 196.9 Minimum Bend Radius 20MM (Dynamic); 10MM (Static) Shipping Dimensions (hwd / in.) 9.00 x 7.00 x 0.50 Shipping Dimensions (hwd / cm) 22.86 x 17.78 x 1.27 Shipping Weight (lbs.) 0.07 Shipping Weight (kg) 0.04 ENVIRONMENTAL Operating Temperature Range -4 to 140 °F (-20 to 60 °C) Storage Temperature Range -4 to 140 °F (-20 to 60 °C) Operating Humidity Range 5% to 85% RH, Non-Condensing Storage Humidity Range 35% to 65% RH, Non-Condensing COMMUNICATIONS Network Compatibility 1 Gbps (Gigabit); 10 Gbps Attenuation @ 850NM 3.0dB/Km Insertion Loss MTRJ0.50dB; SC0.20dB CONNECTIONS Side A - Connector 1 MTRJ DUPLEX (MALE) Side B - Connector 1 SC DUPLEX (MALE) Endface Polish PC FEATURES & SPECIFICATIONS Push/Pull Tabs No Breakout No Trunk No STANDARDS & COMPLIANCE Product Compliance RoHS; REACH 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
N310-05M 价格&库存
很抱歉,暂时无法提供与“N310-05M”相匹配的价格&库存,您可以联系我们找货
