N366-01M
N366-01M
    TRIPPLITE
    CABLE FIBER OPTIC DUPLEX 1M
N366-01M 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Duplex Singlemode 9/125 Fiber Patch Cable (LC/SC), 1M (3 ft.) MODEL NUMBER: N366-01M Highlights ● Premium PVC 9/125 micron singlemode patch cables ● Attenuation loss meets or exceeds the latest industry standards ● Twice the bandwidth throughput of multimode cable System Requirements ● Any fiber optic hardware or NIC card requiring singlemode duplex cable with LC/SCconnectors Package Includes ● Features ● Manufactured from 9/125 duplex (zipcord) fiber ● PVC jacket ● Length: 1-meter. Connectors: 2 SC and 2 LC connectors on each end ● Insertion loss testing performed on every connector (0.2db typical) and provided with cable ● Beveled edge on ends of glass makes insertion of plug a breeze ● Fiber made from glass (not a polymer) ● Fiber optic distributed data interface (FDDI) rated ● OFNR (riser rated) Specifications OVERVIEW UPC Code 037332100535 Technology Singlemode Optical Mode OS2 PHYSICAL Cable Jacket Color Yellow Connector Color Blue; Blue; White Cable Jacket Material LSZH Cable Jacket Rating OFNR 1/3 1-meter Duplex Single mode Fiber Patch Cable, LC/SC 1000 Eaton Boulevard Cleveland, OH 44122 United States Clad Diameter (microns) 125 Core Diameter (microns) 9 Number of Fibers 2 Cable Length (ft.) 3.3 Cable Length (m) 1.01 Cable Length (in.) 39.4 Minimum Bend Radius 20MM (Dynamic); 10MM (Static) Shipping Dimensions (hwd / in.) 0.25 x 6.00 x 7.00 Shipping Dimensions (hwd / cm) 0.64 x 15.24 x 17.78 Shipping Weight (lbs.) 0.05 Shipping Weight (kg) 0.02 ENVIRONMENTAL Operating Temperature Range -4 to 140 °F (-20 to 60 °C) Storage Temperature Range -4 to 140 °F (-20 to 60 °C) Operating Humidity Range 5% to 85% RH, Non-Condensing Storage Humidity Range 35% to 65% RH, Non-Condensing COMMUNICATIONS Network Compatibility 1 Gbps (Gigabit); 10 Gbps; 25 Gbps; 40 Gbps; 100 Gbps; 400 Gbps Attenuation @ 1310NM 0.36dB/Km Attenuation @ 1550NM 0.22dB/Km Insertion Loss 0.30dB CONNECTIONS Side A - Connector 1 LC DUPLEX (MALE) Side B - Connector 1 SC DUPLEX (MALE) Endface Polish UPC FEATURES & SPECIFICATIONS Push/Pull Tabs No Breakout No Trunk No STANDARDS & COMPLIANCE Product Compliance RoHS; REACH 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
N366-01M 价格&库存
很抱歉,暂时无法提供与“N366-01M”相匹配的价格&库存,您可以联系我们找货
N366-01M
  • 1+165.281911+20.72667
  • 10+140.4716210+17.61541
  • 25+131.6760025+16.51243
  • 50+125.3920350+15.72440
  • 100+119.41120100+14.97440
  • 250+111.94165250+14.03770
  • 500+108.83352500+13.64794
库存:12
