N506-01M
N506-01M
    TRIPPLITE
    CABLE FIBER OPTIC DUPLEX 3'
N506-01M 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Duplex Multimode 50/125 Fiber Patch Cable (SC/SC), 1M (3 ft.) MODEL NUMBER: N506-01M Highlights ● Premium PVC 50/125 multimode patch cables ● Attenuation loss meets or exceeds the latest industry standards ● Higher bandwidth optimized for gigabit and 10Gbps networks ● Backward compatible with 62.5 micron fiber ● Built-in headroom for future applications System Requirements ● Any fiber optic hardware or NIC card requiring multimode duplex cable with SC/SC connectors Package Includes ● Features ● Constructed with 50/125 micron cable ● Length - 1M ● Use on fiber and fibre channel installations ● SC male to SC male connectors ● Higher bandwidth optimized for Gigabit and 10Gbps networks ● Backward compatible with 62.5 micron fiber ● Built-in headroom for future applications ● Number of fibers: 2 ● Fiber type: all glass graded index ● Core diameter: two 50+/-3 microns ● CLAD diameter: 125+/-2 microns ● Primary coating diameter: 245+/-15 microns ● Primary coating material: acrylate ● Secondary coating diameter: 900+/-50 microns ● Secondary coating material: PVC ● Attenuation @850NM: 3.5DB/KM maximum, @1300NM: 1.0DB/KM maximum ● Bandwidth @850NM: 220 MHz-KM minimum, @1300NM: 600 MHz-KM minimum ● Numeric aperture: .275 nominal ● Proof test level: 100,000 PSI ● Insertion loss testing performed on every connector (0.2db typical) and provided with cable ● Beveled edge on ends of glass makes insertion of plug a breeze Specifications 1/3 1M duplex MMF cable SC/SC 50/125 fiber 1000 Eaton Boulevard Cleveland, OH 44122 United States OVERVIEW UPC Code 037332119438 Technology Multimode Optical Mode OM2 PHYSICAL Cable Jacket Color Orange Connector Color Beige Cable Jacket Material LSZH Cable Jacket Rating OFNR Clad Diameter (microns) 125 Core Diameter (microns) 50 Number of Fibers 2 Cable Length (ft.) 3.3 Cable Length (m) 1.01 Cable Length (in.) 39.4 Minimum Bend Radius 20MM (Dynamic); 10MM (Static) Shipping Dimensions (hwd / in.) 9.00 x 7.00 x 0.50 Shipping Dimensions (hwd / cm) 22.86 x 17.78 x 1.27 Shipping Weight (lbs.) 0.06 Shipping Weight (kg) 0.03 ENVIRONMENTAL Operating Temperature Range -4 to 140 °F (-20 to 60 °C) Storage Temperature Range -4 to 140 °F (-20 to 60 °C) Operating Humidity Range 5% to 85% RH, Non-Condensing Storage Humidity Range 35% to 65% RH, Non-Condensing COMMUNICATIONS Network Compatibility 1 Gbps (Gigabit); 10 Gbps Attenuation @ 850NM 3.0dB/Km Insertion Loss 0.20dB CONNECTIONS Side A - Connector 1 SC DUPLEX (MALE) Side B - Connector 1 SC DUPLEX (MALE) 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States Endface Polish PC FEATURES & SPECIFICATIONS Push/Pull Tabs No Breakout No Trunk No STANDARDS & COMPLIANCE Product Compliance RoHS; REACH WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
N506-01M 价格&库存
很抱歉,暂时无法提供与“N506-01M”相匹配的价格&库存,您可以联系我们找货
