N816-02M
N816-02M
    TRIPPLITE
    N816-02M
N816-02M 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States OM3 can support 40GBASE-SR4 / 100GBASE-SR10 in applicable parallel optics networks 10Gb Duplex Multimode 50/125 OM3 LSZH Fiber Patch Cable (LC/SC) - Aqua, 2M (6 ft.) Highlights ● 2 Meter LC/SC 10Gb 50/125 Aqua Fiber Patch Cable...OM3 Rated ● Designed for 10-Gig Ethernet applications ● Backward compatible with existing 50/125 fiber ● Max 10Gb distance of 300 meters @850nm ● Low-Smoke, Zero Halogen (LSZH) Aqua jacket MODEL NUMBER: N816-02M Package Includes 2 meter ( 6.5 ft ) Duplex Multimode 50/125 Aqua OM3 Fiber Patch Cable, SC/LC Features ● 2 Meter LC/SC 10Gb 50/125 Aqua Fiber Patch Cable, OM3 Rated ● 10gb Ethernet speed to 300 meters @850nm ● Use with VCSEL and LED laser light sources ● High-Speed, High-Bandwidth, Low-Cost ● Backward compatible with legacy LAN's ● Ideal for Fibre Channel (SAN) applications ● IEEE 802.3ae and TIA LOMMF compliant Specifications OVERVIEW UPC Code 037332139764 Technology Multimode Optical Mode OM3 PHYSICAL Cable Jacket Color Aqua Connector Color White; Beige Cable Jacket Material LSZH Cable Jacket Rating OFNR 1/3 1000 Eaton Boulevard Cleveland, OH 44122 United States Clad Diameter (microns) 125 Core Diameter (microns) 50 Number of Fibers 2 Cable Length (ft.) 6.6 Cable Length (m) 2.01 Cable Length (in.) 78.7 Minimum Bend Radius 20MM (Dynamic); 10MM (Static) Shipping Dimensions (hwd / in.) 0.25 x 6.00 x 7.00 Shipping Dimensions (hwd / cm) 0.64 x 15.24 x 17.78 Shipping Weight (lbs.) 0.05 Shipping Weight (kg) 0.02 ENVIRONMENTAL Operating Temperature Range -4 to 140 °F (-20 to 60 °C) Storage Temperature Range -4 to 140 °F (-20 to 60 °C) Operating Humidity Range 5% to 85% RH, Non-Condensing Storage Humidity Range 35% to 65% RH, Non-Condensing COMMUNICATIONS Network Compatibility 1 Gbps (Gigabit); 10 Gbps; 25 Gbps; 40 Gbps; 100 Gbps Attenuation @ 850NM 3.0dB/Km Insertion Loss LC0.20dB; SC0.20dB CONNECTIONS Side A - Connector 1 SC DUPLEX (MALE) Side B - Connector 1 LC DUPLEX (MALE) Endface Polish PC FEATURES & SPECIFICATIONS Push/Pull Tabs No Breakout No Trunk No STANDARDS & COMPLIANCE Product Compliance RoHS; REACH WARRANTY & SUPPORT 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States Product Warranty Period (Worldwide) Lifetime limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
N816-02M 价格&库存
很抱歉,暂时无法提供与“N816-02M”相匹配的价格&库存,您可以联系我们找货
