N518-05M
N518-05M
    TRIPPLITE
    N518-05M
N518-05M 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Duplex Multimode 50/125 Fiber Patch Cable (LC/ST), 5M (16 ft.) MODEL NUMBER: N518-05M Highlights ● Perfect for use with Fibre Channel Controller Cards and Switches ● Attenuation loss meets or exceeds the latest industry standards ● Higher bandwidth, optimized for gigabit and 10Gbps networks ● Backward compatible with 62.5 micron fiber ● Built-in headroom for future applications ● Premium PVC multimode patch cables System Requirements ● Any fiber optic hardware or NIC card requiring multimode duplex cable with LC/ST connectors Package Includes ● Features ● Constructed with 50/125 micron cable ● Length - 5M ● Use on fiber and fibre channel installations ● LC male to ST male connectors ● Higher bandwidth optimized for gigabit and 10Gbps networks ● Backward compatible with 62.5 micron fiber ● Built-in headroom for future applications Specifications OVERVIEW UPC Code 037332123633 Technology Multimode Optical Mode OM2 PHYSICAL Cable Jacket Color Orange Connector Color Gray; Red; Black Cable Jacket Material LSZH Cable Jacket Rating OFNR Clad Diameter (microns) 125 1/3 5M duplex MMF cable LC/ST 50/125 fiber 1000 Eaton Boulevard Cleveland, OH 44122 United States Core Diameter (microns) 50 Number of Fibers 2 Cable Length (ft.) 16.4 Cable Length (m) 5.00 Cable Length (in.) 196.9 Minimum Bend Radius 20MM (Dynamic); 10MM (Static) Shipping Dimensions (hwd / in.) 9.00 x 7.00 x 0.50 Shipping Dimensions (hwd / cm) 22.86 x 17.78 x 1.27 Shipping Weight (lbs.) 0.08 Shipping Weight (kg) 0.04 ENVIRONMENTAL Operating Temperature Range -4 to 140 °F (-20 to 60 °C) Storage Temperature Range -4 to 140 °F (-20 to 60 °C) Operating Humidity Range 5% to 85% RH, Non-Condensing Storage Humidity Range 35% to 65% RH, Non-Condensing COMMUNICATIONS Network Compatibility 1 Gbps (Gigabit); 10 Gbps; 25 Gbps Attenuation @ 850NM 3.0dB/Km Insertion Loss LC0.20dB; ST0.20dB CONNECTIONS Side A - Connector 1 LC DUPLEX (MALE) Side B - Connector 1 ST DUPLEX (MALE) Endface Polish PC FEATURES & SPECIFICATIONS Push/Pull Tabs No Breakout No Trunk No STANDARDS & COMPLIANCE Product Compliance RoHS; REACH WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
N518-05M 价格&库存
很抱歉,暂时无法提供与“N518-05M”相匹配的价格&库存,您可以联系我们找货
