1000 Eaton Boulevard
Cleveland, OH 44122
United States
Duplex Multimode 62.5/125 Fiber Patch Cable
(LC/LC), 6M (20 ft.)
MODEL NUMBER: N320-06M
Highlights
Manufactured from 62.5/125
duplex (Zipcord) fiber
Length: 6-meters / Connectors:
2 LC connectors on each end
Insertion loss testing performed
on every connector (0.2dB
typical)
Duplex multimode fiber is most
commonly used in LAN
applications where links are 10
feet or less
Fiber Optic Distributed Data
Interface (FDDI) Rated
System Requirements
Any fiber optic hardware or NIC
card requiring multimode duplex
cable with LC connectors
Package Includes
Features
Manufactured from 62.5/125 duplex (zipcord) fiber
PVC jacket
Length: 6-meters/Connectors: 2 LC connectors on each end
Insertion loss testing performed on every connector (0.2db typical) and provided with cable
Beveled edge on ends of glass makes insertion of plug a breeze
Fiber made from glass (not a polymer)
Duplex multimode fiber is most commonly used in LAN applications where links are 10-ft. (3.05 m) or
less
Fiber optic distributed data interface (FDDI) rated
OFNR (riser rated)
Specifications
OVERVIEW
UPC Code
037332138644
Technology
Multimode
Optical Mode
OM1
PHYSICAL
Cable Jacket Color
Orange
Connector Color
Gray
Cable Jacket Material
LSZH
1/3
6-meter Duplex MMF LC/LC
62.5/125 Micron Fiber Cable
Cleveland, OH 44122
United States
Cable Jacket Rating
OFNR
Clad Diameter (microns)
125
Core Diameter (microns)
62.5
Number of Fibers
2
Cable Length (ft.)
19.7
Cable Length (m)
6.01
Cable Length (in.)
236.2
Minimum Bend Radius
20MM (Dynamic); 10MM (Static)
Shipping Dimensions (hwd / in.)
9.00 x 7.00 x 0.50
Shipping Dimensions (hwd / cm)
22.86 x 17.78 x 1.27
Shipping Weight (lbs.)
0.12
Shipping Weight (kg)
0.05
ENVIRONMENTAL
Operating Temperature Range
-4 to 140 °F (-20 to 60 °C)
Storage Temperature Range
Operating Humidity Range
5% to 85% RH, Non-Condensing
Storage Humidity Range
35% to 65% RH, Non-Condensing
COMMUNICATIONS
Network Compatibility
1 Gbps (Gigabit); 10 Gbps
Attenuation @ 850NM
3.0dB/Km
Insertion Loss
0.20dB
CONNECTIONS
Side A - Connector 1
LC DUPLEX (MALE)
Side B - Connector 1
LC DUPLEX (MALE)
Endface Polish
PC
FEATURES & SPECIFICATIONS
Push/Pull Tabs
No
Breakout
No
Trunk
No
STANDARDS & COMPLIANCE
Product Compliance
RoHS; REACH
2/3
Cleveland, OH 44122
United States
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
Lifetime limited warranty
© 2022 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
3/3
很抱歉,暂时无法提供与“N320-06M”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+254.494861+32.96599
- 10+216.3179610+28.02075
- 25+202.7718025+26.26604
- 50+193.0984250+25.01300
- 100+183.88778100+23.81990
- 250+172.38840250+22.33033
- 500+164.17138500+21.26594
