N352-01M
N352-01M
    TRIPPLITE
    N352-01M
N352-01M 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Duplex Singlemode 9/125 Fiber Patch Cable (ST/ST), 1M (3 ft.) MODEL NUMBER: N352-01M Highlights ● Premium PVC 9/125 micron singlemode patch cables ● Attenuation loss meets or exceeds the latest industry standard ● Twice the bandwidth throughput of multimode cable System Requirements ● Any fiber optic hardware or NIC card requiring singlemode duplex cable with ST/ST connectors Package Includes ● Features ● Manufactured from 9/125 duplex (zipcord) fiber ● PVC jacket ● Length: 1-meter ( 3ft ) Connectors: 2 ST connectors on each end ● Insertion loss testing performed on every connector (0.2db typical) and provided with cable ● Beveled edge on ends of glass makes insertion of plug a breeze ● Fiber made from glass (not a polymer) ● Fiber optic distributed data interface (FDDI) rated ● OFNR (riser rated) Specifications OVERVIEW UPC Code 037332122667 Technology Singlemode Optical Mode OS2 PHYSICAL Cable Jacket Color Yellow Connector Color Black Cable Jacket Material LSZH Cable Jacket Rating OFNR 1/3 1-meter ( 3ft ) Duplex Singlemode Fiber Patch Cable, ST/ST 1000 Eaton Boulevard Cleveland, OH 44122 United States Clad Diameter (microns) 125 Core Diameter (microns) 9 Number of Fibers 2 Cable Length (ft.) 3.3 Cable Length (m) 1.01 Cable Length (in.) 39.4 Minimum Bend Radius 20MM (Dynamic); 10MM (Static) Shipping Dimensions (hwd / in.) 0.10 x 5.20 x 5.90 Shipping Dimensions (hwd / cm) 0.25 x 13.21 x 14.99 Shipping Weight (lbs.) 0.05 Shipping Weight (kg) 0.02 ENVIRONMENTAL Operating Temperature Range -4 to 140 °F (-20 to 60 °C) Storage Temperature Range -4 to 140 °F (-20 to 60 °C) Operating Humidity Range 5% to 85% RH, Non-Condensing Storage Humidity Range 35% to 65% RH, Non-Condensing COMMUNICATIONS Attenuation @ 1310NM 0.36dB/Km Attenuation @ 1550NM 0.22dB/Km Insertion Loss 0.30dB CONNECTIONS Side A - Connector 1 ST DUPLEX (MALE) Side B - Connector 1 ST DUPLEX (MALE) Endface Polish UPC FEATURES & SPECIFICATIONS Push/Pull Tabs No Breakout No Trunk No STANDARDS & COMPLIANCE Product Compliance RoHS; REACH WARRANTY & SUPPORT 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States Product Warranty Period (Worldwide) Lifetime limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
N352-01M
物料型号:N352-01M
器件简介:这是一根1米(3英尺)长的双工单模光纤跳线,型号为N352-01M,采用9/125微米单模光纤,具有ST/ST连接器。
引脚分配:文档中未明确提供引脚分配信息,但提到了每端有两个ST连接器。
参数特性: - 技术:单模 - 光模式:OS2 - 包层直径:125微米 - 芯径:9微米 - 光纤数量:2 - 电缆长度:3.3英尺(1.01米) - 最小弯曲半径:20毫米(动态);10毫米(静态) - 工作温度范围:-4至140°F(-20至60°C) - 存储温度范围:-4至140°F(-20至60°C) - 工作湿度范围:5%至85% RH,非凝结 - 存储湿度范围:35%至65% RH,非凝结 - 衰减@1310NM:0.36dB/Km - 衰减@1550NM:0.22dB/Km - 插入损耗:0.30dB
功能详解:该光纤跳线具有高带宽吞吐量,是多模光纤的两倍,并且插入损耗测试在每个连接器上执行,典型值为0.2dB。光纤由玻璃制成,不是聚合物,并且符合FDDI评级。
应用信息:适用于任何需要单模双工电缆和ST/ST连接器的光纤硬件或NIC卡。
封装信息:电缆外套颜色为黄色,连接器颜色为黑色,电缆外套材料为LSZH,电缆外套等级为OFNR。
N352-01M 价格&库存
很抱歉,暂时无法提供与“N352-01M”相匹配的价格&库存,您可以联系我们找货
N352-01M
  • 1+152.332171+19.73235
