N820-01M-OM4
N820-01M-OM4
    TRIPPLITE
    FIBERPATCHCABLELC/LCAQUA3FT
N820-01M-OM4 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States 10Gb/100Gb Duplex Multimode 50/125 OM4 LSZH Fiber Patch Cable (LC/LC) - Aqua, 1M (3 ft.) MODEL NUMBER: N820-01M-OM4 Highlights ● Designed for 40/100-Gig Ethernet applications...OM4 Rated ● Backward compatible with existing 50/125 fiber ● Max 40/100Gb distance of 300 meters @850nm ● Low-Smoke, Zero Halogen (LSZH) Aqua jacket Package Includes ● Features ● 1 Meter ( 3ft ) LC/LC, OM4 Rated ● 40/100gb Ethernet speed to 300 meters @850nm ● Use with VCSEL and LED laser light sources ● High-Speed, High-Bandwidth, Low-Cost ● Backward compatible with legacy LAN's ● Ideal for Fibre Channel (SAN) applications ● IEEE 802.3ae and TIA LOMMF compliant Specifications OVERVIEW UPC Code 037332165213 Technology Multimode Optical Mode OM4 PHYSICAL Cable Jacket Color Aqua Connector Color Aqua Cable Jacket Material LSZH Cable Jacket Rating OFNR Clad Diameter (microns) 125 1/3 1 meter ( 3ft ) Duplex Multimode 50/125 Aqua OM4 Fiber Patch Cable, LC/LC 1000 Eaton Boulevard Cleveland, OH 44122 United States Core Diameter (microns) 50 Number of Fibers 2 Cable Length (ft.) 3.3 Cable Length (m) 1.01 Cable Length (in.) 39.4 Minimum Bend Radius 20MM (Dynamic); 10MM (Static) Shipping Dimensions (hwd / in.) 0.25 x 6.00 x 8.00 Shipping Dimensions (hwd / cm) 0.64 x 15.24 x 20.32 Shipping Weight (lbs.) 0.05 Shipping Weight (kg) 0.02 ENVIRONMENTAL Operating Temperature Range -4 to 140 °F (-20 to 60 °C) Storage Temperature Range -4 to 140 °F (-20 to 60 °C) Operating Humidity Range 5% to 85% RH, Non-Condensing Storage Humidity Range 35% to 65% RH, Non-Condensing COMMUNICATIONS Network Compatibility 1 Gbps (Gigabit); 10 Gbps; 25 Gbps; 40 Gbps; 100 Gbps Attenuation @ 850NM 3.0dB/Km Insertion Loss 0.20dB CONNECTIONS Side A - Connector 1 LC DUPLEX (MALE) Side B - Connector 1 LC DUPLEX (MALE) Endface Polish PC FEATURES & SPECIFICATIONS Push/Pull Tabs No Breakout No Trunk No STANDARDS & COMPLIANCE Product Compliance RoHS; REACH WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
N820-01M-OM4 价格&库存
很抱歉,暂时无法提供与“N820-01M-OM4”相匹配的价格&库存,您可以联系我们找货
